Why is it if I step on it hard seemingly in the lower rpm range it almost acts like she'll die but a second later picks up and goes?
Things to look at/for? Clean air filter.
Bone stock with 50K.
· Vendor
Get some ACES IV in the gasoline. Gasoline leaves deposits that off the shelf products and even top tier gasolines will not clean out.
Use 1 oz per 6 gallons and after 2-3 tanks, there will be a big difference.....ignition improving, lubricity and detergency.:beerchug:
Regards,
Brian
BND Automotive LLC:driving:
440-821-9040
www.bndautomotive.com
Good to know Hemi, but I'll try Amsoils Performance Improver first. And i have a bottle of there Octane Boost laying around I normally use for the CR500AF dirt bike in the dunes.
And yes Rich I should change the plugs, since I got the car with 47k on it.
· Vendor
iggys-amsoil,
Do you realize that you are using Polyether Amine in your PI?
Polyether Amine produces gum and varnish when burned in the cylinders?
Also petroleum oil with napthlene....which is dry cleaning fluid!
Your PI is oily and so will your octane booster be oily!
You are adding more carbon to your oils by doing this and attacking seals!
Polyeter Amine 30 - 60%
Base Oil(s)* 10 - 30 %
Naphthalene 0.1 - 1%
http://www.amsoil.com/msds/api.pdf
You may not care because you are an Amsoil Distributor....but your car does!
ACES IV contains octane enhancing, detergency, lubricity, anti-corrosion agents, anti-oxidants, metal deactivators, cold flow improvers, seal conditioners and is much better for your vehicles!! You just need 1 product instead!;)
Regards,
Brian
440-821-9040
Start running chevron gas every 4th tank and throw a bottle of chevron techron fuel system cleaner in there. It'll do the trick.
There is also a fuel injector cleaner in a mettle container, b something. Stuff is very good but you need to burn through it in a few days. Used it to clean some injectors on a high boost motor once. It's in mettle because in a month it'll eat threw plastic. Put in with a fuel tank and run dry.
