Do they have the silver square boxes screwed into the side that say high voltage and are branded Osram? They're the HID ballasts... you'll need those. Apart from that, as long as the harnesses connect for power, you should be good to go. I can't say if the power connections on the headlight assembly are the same or not between halogen and HID because I haven't seen.
