1 - 6 of 6 Posts
Anyone know the interior dimensions of the trunk for the '11 Mopar Edition, or contact information for someone at Dodge/Chrysler who might know? I've discovered that it is definitely different from the other models, partially due to the sway bars, but that only accounts for part of the discrepancy. I've now tried trunk cargo liners from two different manufacturers, both designed specifically to fit the 2011 Charger (w/o the optional subwoofer), and both are too large by a lot. I am going to need to cut it to fit, and it would really help me do a better job if I could create a cardboard template with the exact dimensions to use as a guide.
I really need to protect my trunk from gasoline spills (related thread here)
Thanks in advance for any advice!
I don't know how thats possible. They wouldn't do a different trunk. The main difference between the mopar 11 and regular charger is some interior badges, seat coverings, front/rear strut tower braces, pistol grip gear shift knob, 3.91 gears and black mono paint with a blue stripe.
I think the makers are just saying they'll work in a 2011 and not laser cut to fit the 2011-up. I'd guess someone is lying to you?!?
· Premium Member
^^^^This!^^^^
The Mopar 11 has a factory installed rear tower brace and the other 2011 Chargers don't. In the picture below you can see that the only difference on the Mopar 11 is the presence of the brace. All other interior trunk dimensions (and panels) are the same.
Thanks for the picture, D! That would do it.
I had a different rear brace in mine, which only had parallel bars across, no down tubes. It was the Razor's Edge bar. (Do they still make those?)
1 - 6 of 6 Posts
