1 - 11 of 11 Posts
So.. i hit a deer with my charger and when it happened, i lost all brakes due to the ABS Control Module being destroyed. i have replaced everything mechanically but the car will not start. it acts like it doesnt know im pressing the brake pedal. i try to start but when i press the push button start, instead of going to run it goes to ACC and still tells me to press brake pedal on the display... i know the ABS control module has to mated to the computer at a shop but the dealer tells me that the car should still start. Does anyone have any suggestions or ideas? Im at a loss and out of ideas. please help! i want my baby back!
Do the brake lights illuminate when it goes into ACC when you attempt to start? If not, then perhaps the brake switch was broken on the pedal when you hit the deer too.
I didn't think about that. I'm checking that right now. Hopefully that's the problem because we are seriously out of ideas and I was just about to call the tow truck to take to a dealer.. I know it's gonna have to go to a dealer eventually for the new ABS Control Module but I'm hoping to drive it there instead of tow lol..
So there is no brake lights coming on. I got down under the pedal and found the connector for the switch and it looks fine to me. I unplugged it, Plugged it back in. Everything is fine. But still will not start. Going to check fuses now. Hmm...
please help
i have a dodge charger 06 3.5 ho i changed the engine a time ago
now i have a couple of problems such as performance go up and down , and when i start the car in cold days the rpm keep going up and down for a while is that normal ???!
today my dash boards grears P R N 3 2 L is all marked and it wont start for like a half ahour and i manged to start it but some times when i turn it off and restart it thay marked again ! and the battery is new ???
any idias !
coolrivera999,
Be sure to keep us posted on how things go at the dealership!
rany e j,
I followed up on your concern in another thread.
I have another car a bmw 330 ci
Bt this charger its my first car i just love it
So back to the problem it had 2.7 vs
So i just replaced it with 3.5 h.o vs
The dealership did it all
But after a while i faced alota problems
I fixed most of them
Now all i have is the car some times broke down
It wont start at all and i cant tell if its the starter or smthin else
And the code p0403 "exhaust gas recirculation"
After i strighit pip it
Is this code a serios problem !!
And thanks for the follow up
Excuse my english its not my first lang.
1 - 11 of 11 Posts
