1 - 4 of 4 Posts
Two questions:
My 2010 Charger Pursuit Low Tire Pressure light stays on constantly and beeps every now and then. When I check the pressure with a gauge all four tires show over 50 PSI. The car next to it reads normally as do my motorcycles. Is this a sensor issue and can they cause high pressure readings on a standard slide pressure gauge?
The build sheet that Chrysler sent me has a lot of good information. As far as fuel capacity is lists a 19-gallon fuel tank. About a half page down lists 8 additional gallons of fuel. The question is, is it one 27-gallon tank, or is the additional 8 a separate tank?
I haven't been under her yet but am planning to rebuild both the front and rear suspension with the help of my daughter as this is her first car and I want to make sure she understands it.
Appreciate any information you guys can provide.
Welcome!
My first guess is the TPMS sensor batteries failed long ago; So the warning light is likely lighting due to the lack of any reading at all.
No clue on your gas tank question. Drive it to near empty and fill it up.
I have a '15 Pursuit and need to replace the entire drivetrain from the transmission to the wheel hubs; mine is a 5.7 AWD.
2011 Charger Pursuit
Overpressure can trigger light as well I believe. 50psi is too much.
1 - 4 of 4 Posts
