Since getting my SuperBee a few days ago i've noticed something;while driving it seems like the car is kind of sluggish or slow to respond when pressing moderately on the pedal. When you stomp on the pedal or step on it, say, 75% of the way, you get a nice fast response but not so much when you only depress the pedal 0-50% of the way.
I thought maybe something was wrong with the car but today I was reading a big orange sheet that came with my car which explains all the unique features that come in an SRT8 and I noticed something interesting.
The sheet said that this car is equipped with a 1-4 shift skip feature which is intended to save gas/improve fuel economy. Apparently under 'normal' driving conditions the car goes from 1st gear immediately to 4th.
In order to test this, I drove away from a stop at 'regular' speed and as soon as the tachometre needle drops indicating a gear shift has occurred, I would click the autostick to the right. Sure enough, when I shifted to the right, I was in 5th gear!!!
So apparently the car DOES switch right into 4th gear which explains why when i'm driving and I give it a LITTLE gas it seems to not respond with the force I would expect from an SRT8 (because it's in 4th gear... d'uh!) ...and when I give it considerably more gas or stomp on it, the trasmission downshifts and takes off as per usual.
Is this a new feature in 2009's or does this happen with 2006-2008 SRT8's (I dont remember this happening on my 2008).
I guess auto-stick is less useless now as you will need to use it to moderately accelerate without stomping the gas and blowing away all your hard earned premium fuel.
The owners manual also warns that while the car is in autostick, it will NOT shift gears when the engine has reached maximum speed which leads me to believe you will bounce off the rev limiter?
The manual claims the only time the car will shift on it's own or over-ride you is when you want to shift the car into gears that are way too high for the speed you're going (it wont shift), or when the car comes to a stop it will reset to 1st gear.
It also states that the EVIC will display "UPSHIFT" when you are at optimal RPM and/or forget the car is in auto-stick mode.
Interesting stuff... what are you guys experiencing???
