1 - 6 of 6 Posts
Discussion Starter #2
Leak
I can smell radiator fluid. None on floor of garage. I think the tank is leaking. How can I find out ? I mean it looks like the cap. Do the caps of the tank have a problem with leaking?
Vendor
What year Charger do you have?
As they get older, they do tend to leak. You can take it to any local store and have them test it to see if it is holding pressure.
If not, replace it.;)
Regards,
Brian
BND Automotive LLC:driving:
440-821-9040
www.bndautomotive.com
Take the cap off when the engine is cold and look at the underside. Is the rubber gasket cracked? If so, replace it.
Although I suspect you really have a water pump gasket leak that you haven't found yet. Mine had one for nearly 2 years that I could smell long before I could see it. I also started trying to fix it by replacing the reservoir cap...
1 - 6 of 6 Posts
