1 - 8 of 8 Posts
Found mine on ebay! Works perfectly!!
All bezels from 06-07 will fit , are you sure its for the Charger ?? It should look like this
It should fit perfectly. I put an '07 Super Bee Bezel in my '06 SRT. Just make sure you have all the wires tucked back in right and the climate controls & ESP/Hazard light panels are screwed in to place correctly. Other issues could be the air vents not seating all the way or one of the mounting clips are missing the hole when you put it in.
Specifically, what's not fitting right? Maybe we can help you more.
What does the super bee bezel look like? Is it just yellow?
It's imitation carbon fiber. The bezel around the shifter in the Bee is also the same.
1 - 8 of 8 Posts
