I have a 2007 dodge charger daytona, i have a problem with my heater, its has dual ac /heater control, one for driver and one for passenger, but the thing is that the passenger side work good and blow hot air, but the driver side even if i put on high temperature blow cold air, that any one has that problem ?
The vent door on that side is stuck open. Costs quite a bit to fix it since you have to disassemble the dash. Same thing happened to mine.
It's the driver side Blend-air door or actuator. The actuator can be replaced without taking apart the dash but the door itself is a PITA to replace. You may want to investigate/diagnose further whether it's the actuator or the door. You may luck out with it being the actuator.
