Looking for some ideas. I have a front end shake at around 40MPH. Checked outer tie rods. Found one inner that seemed loose so I replaced it. Already repalced front rotors and pads. No visible uneven tire wear. New tires all the way around. Rotated tires and still shakes in the front. Seems mostly from the right as far as I can tell. Does not shake during braking and sometimes it doesn't shake at all. Driving me nuts. I've heard the thrust arms can be problematic. Anyone else experiencing this?
I just started experiencing the same sort of noise. the Charger has 65K miles and is stock. I jacked up the car today and the clunking feels like it is generated from the connection on the steering rack. Its covered up buy the boot. Has any one had the same kind of problems?
I had a shake going on at 40+ and when I took the car to the dealer they told me it was my tires. wrong, it was my driveshaft. The first time I twisted it and it was covered under warranty and the second time I sheared a bolt off the drive shaft and it wasn't covered. I would probably take a look under there just to see.
It was the tires
Had a feeling the tires were the culprit. Replaced the Goodyear Assurance tires with a new set of Bridgestone Turanza's per a recommendation from a tire guy. That did it. Shake is gone.
