2006 Dodge Charger P0302 Code
1K views 4 replies 3 participants last post by  Chaser005
#1 ·
I own a 2006 Dodge Charger Daytona Edition and I keep getting a Cylinder 2 Misfire code. It only happens every other time I do a cold start on the car. I have replaced the spark plugs, coil pack, and all 8 injectors on the car and I’m still getting the code. Not sure what else could be the issue?
#2 ·
If you have the cross-wire cabling the cables connect a coil on one cylinder bank to a spark plug on the opposite cylinder bank (see image below). So check coils and ignition wires for both cylinders 2 & 3. Also check the condition of the spark plug cables/connectors.
299932
SPARK PLUG CABLE RESISTANCE
299933
