1 - 2 of 2 Posts
I have a 2006 dodge charger with the 3.5l v6, ex police car, it still has the middle console with all the wires cut, it has a new starter in it and has jumper cables hooked up to the battery when I try to start it, there's a clicking noise coming from inside the car on the passenger side when I turn the key on and when its moved to the start position, there is a small black box that is obviously not factory its fastened to the carpet, inside the box is 3 relays that are the same as the starter relay and horn relay located under the hood, does any one have any idea what these relays are and if they have to do with my starting problems?
Let's start here:
Did the car ever start and run for you, or did you buy it in this condition?
Have you scanned for DTCs? If so, exactly what did you use to do that, and what codes did you get?
1 - 2 of 2 Posts
