Just tried it, cleared codes till I started it gave me p0031 p0037 p0051 and engine was just shaking , did I maybe burn the tcim? The jumper is not installed at the moment , and it still shuts off and starts back up and runs a bit better
POO31
Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 harness is open shorted to ground
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit poor electrical connection
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 1 circuit fuse
- Faulty Engine Control Module (ECM)
PO037
Faulty Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 fuse
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 harness is open or shorted
- Heated Oxygen Sensor (H2OS) Bank 1 Sensor 2 circuit poor electrical connection
- Faulty Engine Control Mo e (ECM)
POO51
Faulty Heated Oxygen Sensor (H2OS) Bank 2 Sensor 1
- Heated Oxygen Sensor (H2OS) Bank 2 Sensor 1 harness is open shorted
- Heated Oxygen Sensor (H2OS) Bank 2 Sensor 1 circuit poor electrical connection
- Heated Oxygen Sensor (H2OS) Bank 2 Sensor 1 fuse
So according to the codes,you have both O2 sensor circuit problems on bank 1,rear sensor circuit problem on right bank.Have you done anything that would cause these codes like working on wiring or did it just start? Its hard to believe all those sensors would be bad at once,so im think a wiring problem like a short!
