1 - 4 of 4 Posts
Lately I’ve been noticing when stopped at a red light or stop sign my engine is idling low, around 450-500 rpms. It idles normally at 700, especially with a load on the engine like the AC. With no load and after rolling to a stop it’s barely maintains 500. If I gently tap the throttle pedal the rpms instantaneously drop even lower then it recovers to 700.
Any ideas?
As far as I know, it's normal for idle to be higher when the transmission is in park than when it's in drive. In almost every car I've ever owned, that's been the case.
JH:
Just for giggles, I would have the battery load tested. If you are still under the 3/36 warranty, would not hurt to let the dealer check/document the issue in case something would develop later. Beyond that, I would monitor and continue to enjoy those 485 hp.
Don
1 - 4 of 4 Posts
