1 - 2 of 2 Posts
Hey all. Happy Spring :)
I wanted to start browsing wheels to possibly replace my chrome clad 20" stocks. Just want to ensure I have the specifics correct.
Per build sheet.
TVJP 245/45R20 BSW AS Performance Tires
WPGP 20X8.0 Aluminum Chrome Clad Wheels
What are my options?
Cheers all!
You need to know the OFFSET too: most 8" wide Mopar wheels (RWD) have a 24mm offset. Use this calculator to figure out which will fit best using your 8"w, 24MM offset as a base:
https://www.1010tires.com/Tools/Wheel-Offset-Calculator#
Do you want to stick to Factory wheels or go aftermarket? There are lots of options available to you. Here is a pic of 2014 and up factory wheels by Hollander interchange code that you can google (IE MOPAR + WHEEL +2527)
1 - 2 of 2 Posts
