Alright, I'm new here but I've done alot of creeping on this site, I can't find a direct answer and I wouldn't mind hearing someone else's opinion, I was driving one day and I got a ding, I looked at my cluster and I had the low tire pressure warning, I drove another 2 days without checking ( stupid me) and out of no where I get another ding, this time I get 3 lights plus my low pressure, so I get the abs, eps/bas and the traction control. So I pulled over and turned the car off and turn it back on after 2 mins. Still all the warnings. So when I get home I filled the tire up thinking it would get rid of the other 3 lights, wrong! All 3 lights are still there. I ran for codes and I get 1417. I have tried the resetting the ESP ( turning steering wheel left right home) no luck, I checked my axle nuts. Both are tight , i pulled all fuses and unhooked the battery, no lick.I checked all my wires, the only issue I found was a light was on my rear right speed sensor was off the mounting clip a little, there was a slightly melted spot where the wire got rubbed, it did not look like it even melted enough to get to the wire. Just I case I cut, sliced, soldered and melted a rubber shrinking tube over it to protect it from weather. Still nothing has worked. Can anyone give me a opinion other then taking it to a stealership. That's my last option. Oh and btw, I'm posting on my iPhone. So if there's any typos, sorry
