So this is my first post, so thank you in advance for any help you guys can provide.
Well....had the car for a month, bought it used. Had 72k miles. Started to notice a tick, but figured it was the, "Hemi tick." After around 600 miles or so, starting getting the p0308. Long story short, fount out it was a bad lifter. Removed the head, passenger side), replaced all 8 lifters and put everything back together.
Car sounds great, no tick, but now no matter what it will not idle. Keep getting the p0172, p0175, and p0300. Replaced the map sensor, throttle body, plugs, (drivers side were gas washed), checked for leaks, replaced brake booster check valve, coils, and injectors.
I can feel the drivers side exhaust is much warmer than the passenger side, and the rpm just revs up and down before finally cutting off. I'm pretty handy, I've done all the work so far myself. The only thing I can think of at this point is if the car war programmed and now the pcm is confused. I just don't know enough about Hemi's to know if by disconnecting the battery did something funky.
I made sure I followed all of the directions and specs when putting everything back together, but I just have no idea why it's running so rich now, especially on the drivers side which I didn't even touch other than removing the fuel rail to remove the intake manifold.
