1 - 12 of 12 Posts
2012 SRT Charger, 2003 Ram hemi, 2005 Magnum
You have the biggest factory sway bars, I would put in SRT suspension (shocks/springs) for ride and handling. I did this on my R/T and put in the police sway bars.
I'd second the idea of changing springs as well. Cop cars had stiffer than R/T springs but not quite SRT spec but they were also taller as well.
A set of SRT springs and shocks/struts will give you a noticeable drop from stock cop height (on my R/T it didn't drop me too much but still noticeable).
If you want a bit softer try to find some 300 SRT take offs they're the softest followed by Challenger and finally Charger/Magnum.
If you want to go new there is a nice Mopar package that includes all you'd need it is around $500-600 but you won't need anything else like adjustable bits because your alignment goes off after lowering etc. It doesn't seem like you're interested in a drop so I didn't mention coil overs.
I was thinking about putting in the KONI STR.T orange shocks & struts , when i talked to one of the "specialist" on autoanything.com they said those would work great, but I'm still unsure. i don't want to lower lower it, living in kansas the roads would be terrible for a daily driver.
Then go with stock SRT springs/shocks. Lower than an R/T but still decent enough height.
1 - 12 of 12 Posts
