I have put the diablo sport 91 cai setting and a 180 tstat by jet i set my HS and MS fans to 195 and put the SP fan to 185,
are those fan settings the best?
will the car perform better with the EGR on or off?
I also put all new duels from the converters back with super 44's and boom tubes.
CAI BY K an N
The best 0-60mph I did was 5.72 with a little spin and 32lbs of air in the tires.
I was hoping to get into 5.5 at least but the car bogs after the little spin it does then finally revs back up and goes..anybody have that problem too?
not sure about EGR, but i think my fans are about what you did. i too have a lot of your same mods - check my sig. I run 5.2's 0-60 on a warm day. do you have the traction control turned off? it seems like you have it on from the bog you describe.
