1 - 1 of 1 Posts
Am I reading all these posts right. You HAVE to drop the exhaust just to remove the axle?
Or can it be removed by removing the caliper, rotor and wheel hub?
I have a issue I know but thinking it may just be a snapped axle. If like to check that before having to drop the exhayst and drive shaft to tear into the differential.
If I can I'll go pick up a torx socket for the hub tomorrow.
Also can anyone tell me if this is stock spring? And the rubber part between mine is broken up can I just remove it all together. (It's in 3 peaces)
1 - 1 of 1 Posts
