1 - 4 of 4 Posts
Like the title says. i got about 68k miles on my charger, recently while driving.. probably doing 65mph.. on the highway, i hear a chime and a bell and i notice that all my lights flash as if im turning the car on for the first time , my guages die out momentarily and all the lights light up and then everything goes back to normal after about 3-4 seconds.
any ideas of what it could be???
Sounds like similar problems to what I was having. If it happens again, I'd try gently wiggling the key while it is in the ignition switch or just driving around with only the Charger key (remove anything else from your key chain) and see if it happens again.
You can read about my issue at the thread attached:
http://www.chargerforums.com/forums/showthread.php?t=117735
Let me know if you figure it out bro. Best of luck!
I'm having same issue did it to me on the freeway today about 2 times , Really concerned on this issue on what it is . My Bas light stayed lit for a little bit , Did your Bas light stay lit up on the gages after the lights flickered ?:confused:
1 - 4 of 4 Posts
