Hola tengo un 06 dodge charger 2.7 mi problema es q hace unos días iva en la carretera y der repente mi carro se apago,quise encenderlo pero no daba marcha ni nada. Solo prendían las luces. Me an dicho q puede ser la bomba de la gasolina, los relay starter y el relay de la bomba de gasolina, una curiosidad es que cuando trato de encenderlo, en la caja de los fusibles se escucha un sonido como de golpecito, . Eso me pasa en la mañana. Y si regreso en la noche o al día siguiente, mi carro prende hasta que toma la temperatura normal y se apaga otra ves y no enciende, que podrá ser?
Translation: I have a 2006 Charger 2.7 and a few days ago on the road my car turned off. I tried to turn it back on, but nothing happened, only the lights came on. Someone told me it could be the fuel pump, the starter relay or the fuel pump relay. One odd thing is that when I try to start it, I hear a noise coming from the fuse box. This all happens in the morning, if I come back at night or the day after my car will turn on until it gets to operating temperature, at which point it turns off.
Any ideas?
The battery may need to be replaced. How old is it? These cars are very sensitive to having a weak battery.
La batería puede necesitar ser reemplazado. Qué edad tiene? Estos coches son muy sensibles a tener una batería débil.
Those are some good Spanish skills!
Wow, Ddaddy!! I'm impressed with your spanish! Well, when you travel to Puerto Rico again, you'll have more opportunities to speak our first language... 😄👍
Thanks, my written Spanish is getting better only because I have to write 200 page technical documents for our Regulatory filings in Mexico and Central America. I still suck at speaking it.
I'm also getting experience with writing and reading Portuguese for our filings in Brazil. I can't speak that language to save my life but I am starting to be able to read and write it.
We also have filings in the Middle East and North Africa. Arabic remains a complete mystery to me. I just haven't been able to get my head wrapped around the language at all.
Don't even get me started on the Korean and Japanese languages...I'm fascinated by them but I can't grasp them well at all.
French and German I do ok at, but fortunately I haven't had to do much other than read those languages. I can speak French passably enough to get around Paris, but that's about all.
[QUOTE = "Pardo1026, publicación: 3671265, miembro: 146105"]
Hola tengo un 06 Dodge Charger 2.7 mi problema es q hace unos días iva en la carretera y me arrepiento mi carro se apago, quise encenderlo pero no daba marcha ni nada. Solo prendían las luces. Me an dicho q puede ser la bomba de la gasolina, el relé de arranque y el relé de la bomba de gasolina, una curiosidad es que cuando trato de encendidolo, en la caja de los fusibles se escucha un sonido como de golpecito,. Eso me pasa en la mañana. Y si regreso en la noche o al día siguiente, mi carro prende hasta que toma la temperatura normal y se apaga otra ves y no enciende, ¿qué será ser?
[/CITAR]
