1 - 9 of 9 Posts
So, the other day I was driving around, made a few stops in the wife's Charger until i made the trip into the Liquor store.. Drove up, locked the doors with the remote, came out, unlocked the doors and when I tried to start the car.. Nothing (no click or anything) had power and all..
So I had the car towed home to diagnose what is wrong...
Well, first check was battery.. (OK)
Starter Relay (OK)
Fuses (OK)
Grounds (OK)
Battery (OK)
Starter Switch Actuator Pin (OK)
Next is going to be getting the car up on ramps to get at the starter and check the connections there.. any other suggestions would be great..
If the starter & solenoid check out OK, there's the ASD (auto shutdown relay) and the fuel pump relay. You can plug a OBD2/CAN scanner into the car's OBD2 port to see if there's any diagnostic codes for any of the sensors (e.g. cam/crank position sensors, etc ...)
I forgot to mention that I could already hear the fuel pump prime when I turn the ignition on.. but when i checked the ignition wire with a test light, I get nothing going to the starter..
Plus I had swapped the ASD relay around and even tried with a few I have laying around..
If the starter relay is working but no voltage to the starter it could be a problem with the starter/solenoid ground connection (open circuit). It could be the park/neutral position switch or the PCM double start override ... both of these act as starter interlocks. The other interlocks are the brake pedal pressure and brake pedal travel sensors. If the PCM does not see that the brakes are applied it will not engage the starter. Are any diagnostic codes getting logged?
Discussion Starter #5
Well, at this point, I'm going to run a test wire from up top down to the starter and see if it cranks over, cause without the relay in place, I put voltage to the post going to the starter and nothing happened.. Making me think that there is a break in the wire running to the starter..
Or, the starter has left the building.......
Don
Discussion Starter #8
Ok, so I'll end this thread on a good note..
when the weather cleared up good enough to work on the car again, I went back to basics and started to check all the grounds starting from the battery to the front. when I got to the engine, I found 2 loose grounds on the side of the block.. Tightened them up and the car has been starting beautifully ever since..
So, thank you guys for your time and info..
Mustang:
Glad to hear you are back up and running. Also, thanks for returning to fill us on on how it ended.
May you have many more trouble free miles behind the wheel of your Charger.
Don
1 - 9 of 9 Posts
