Ok, First of all I installed Halos before I painted my 06 Charger rt. Everything worked fine up until my battery died. After I charged the battery my key fob, dome light, locks etc Do not work when the car is off. The only thing that works is the secondary cigar lighter in centre console, and halos (which are led and run off that accessory wire). Again this all worked for days before battery died. Now when the key is turned to the ACC positionI have NOTHING, when I turn the car on, the radio, locks, dome all work! When I open a door I can only unlock the door but will not lock unless door is closed ( either one). It sounds like it needs a reprogram, but I don't see how that has completely shut off all my power without a key engaged.
Does anyone have any idea what the hell happened!?!
