Racing Fuel in a 598 V8 vs 91 octane fuel + ACES IV on a dyno - Dodge Charger Forums
post #1 of 28 Old 04-19-2014 Thread Starter
370 HEMI
Supporting Vendor
370 HEMI's Avatar
(Thread Starter)
Outside the Charger Forums we also work with customers that have very high performance engines.
Racing fuels are generally used in these big block engines. However, due to the price of fuel they require ($9.00 per gallon +) to run them, people have been looking for ways to continue to enjoy these high performance engines (in cars and boats) but without the high cost of the fuels needed to run them..
Word of mouth and the internet have brought a lot of these people to us to inquire about ACES IV. In the last year we have picked up over 1500 customers who have now abandoned the use of racing fuels and are now using pump fuels and ACES IV. One of our customers said it best:
“I am tired of financing my weekends!” and “ I am also tired of dumping half my paycheck into the gas tank!”
So, last Friday, one of them was working with a Chevy 598 V8. He has traditionally used racing fuel in this engine. He made an appointment with the dyno shop running a Super Flow SF902 dyno.
http://www.superflow.com/Dynamometers/Engine/sf902.html
The guys there favor racing fuel and feel that these fuels are the best as producing power and torque. When my customer brought them the engine, he wanted to baseline on 110 octane fuel and then wanted to test 91 octane fuel by itself, and then ACES IV in 91 octane fuel to have a full comparison between them.
The guys at the dyno saw the ACES IV and laughed at 1 oz per 6 gallons in 91 as having any chance of doing anything in the 598 compared to the 110.
What happened there created all kinds of questions as to what else we do including nitrous, alcohols (ethyl and methyl) as well as nitromethane and E85.
I was given copies of the dyno runs with 110, 91 and 91 with ACES IV for comparisons. I have authorization from the customer to share the results. I thought it would be good to post them here for review.
Here is the 598 on 110 race fuel. It produced Max 805 hp, 769.2 torque at a 13.5 A/F Ratio
Here is the 598 on 91 octane pump fuel. It produced Max 798.6 hp, 760.9 torque at a 14.6 A/F Ratio
Here is the 598 on 91 octane pump fuel + ACES IV. It produced Max 807.1 hp, 776.3 torque at a 14.7 A/F Ratio
The Racing Fuel is $9.00 per gallon. The 91 was $3.80 per gallon and adding ACES IV made the total price $4.152 per gallon. The ACES IV produced 2.2 hp and 7.1 torque MORE than the racing fuel! It also produced 8.5 more hp and 15.4 torque MORE than the 91 octane alone!
So using 91 and ACES IV in this case would produce more power, more torque and save $4.848 per gallon doing it (53.9% less than racing fuel).
Entitled to your own opinions but not entitled to your own facts!
Regards,
Brian
BND Automotive LLC
440-821-9040
www.bndautomotive.com
More Power, More Torque, Better MPGs - It's "Rocket Fuel For Your Car"
Custom Designed & Custom Blended "ALWAYS beats off the shelf brands"
Better cooling, better protection without all "The Gunk"
370 HEMI is offline
post #2 of 28 Old 04-19-2014
Yuro
Senior Member
Yuro's Avatar
Damn this awesome info(spectacular and probably mind blowing to those guys at the shop) made me miss this pale redhead i was checking out, yum!
TorRed or NoRed!
"WTFO" Sponsored
WTFO weaponry:
Strut Bar V 2.1
"Being a good fiend is like being a photographer, you have to search for the right moment!"
Yuro is offline
post #3 of 28 Old 04-19-2014
Hemi31
Senior Member
Hemi31's Avatar
How about some more information that would apply, like both dynamic and static compression. Lower octane making more power is nothing new if the compression isn't there to support race fuel.
2006 Chrysler 300C
PWR 462,Wilson Intake,lot of Billet Tech,Brembos,8.8 Paramount rear and HTC Nag1 and lots
far.
Hemi31 is offline
post #4 of 28 Old 04-19-2014
Ddaddy
Supporting Member (Lifetime)
Ddaddy's Avatar
Garage
Quote:
But the 110 octane made more power than the straight 91 octane did.
It was only when Aces was added that the lower octane produced more power than the 110 octane did.
That's much different than the engine not being able to support the higher octane. If it couldn't, the 110 octane wouldn't have made more power than the straight 91 octane did. It also wouldn't explain how the Aces added that much additional power over the straight 91 octane.
2006 Charger SRT-8
1969 Dart GTS 340
2012 Chrysler 300C Hemi
1966 Dart GT
All V8 Mopars!
Ddaddy is offline
post #5 of 28 Old 04-20-2014
Hemi31
Senior Member
Hemi31's Avatar
There's a long way between 91 oct and 110. Also what 110 was it ? Leaded , unleaded , oxygenated? Justcause Iit made less power on pump doesn't disprove my statement. Aftermarket additives such as Torco will raise 91 octane to 100 when mixed right.Also just to clsrify.....we are talking less than 10 hp between the lowest pull on 91 and the highest on aces. If you can only gain 10 hp on fuel you don't need race gas.
Hemi31 is offline
post #6 of 28 Old 04-20-2014 Thread Starter
370 HEMI
Supporting Vendor
370 HEMI's Avatar
(Thread Starter)
I will find out the static and dynamic compression on the engine from him and also what 110 it was as a baseline.
But SERIOUSLY......Torco does NOT raise octane 9 full octane points. Only tetraethyl or tetramethyl lead can do that! Torco may raise it 1 full octane point with the Manganese. ACES IV doesn't raise octane in that fashion either!
It is how it functions at peak heat release that makes the difference WHILE lubricating the cylinders and allowing for reduced friction and wear.
People on this forum search for 10 hp and 8 ft lbs of torque and spend a lot more than what ACES IV costs per gallon.
Give some credit where it is due. Just because you don't like us shouldn't get you so upset. Hey, we offered to have you come and prove it to yourself a few years ago when Cherry invited you to Big Shot Dyno in Tallmadge and bring your car and you refused to do so!
Brian
BND Automotive LLC
440-821-9040
370 HEMI is offline
post #7 of 28 Old 04-20-2014
Hemi31
Senior Member
Hemi31's Avatar
Actually yes Torco will raise octane that much. 32oz into 5 gallons gas is the mix.....ah crap you were right....it doesn't raise it 9, it raises it 14.
http://torcoracefuel.net/2-docs/acce...lend-chart.pdf
And Brian contrary to what you might believe I have tried your stuff. When you were giving it away like water at the 2009 LX&B at Quaker City. It did absolutely nothing and I actually saw a decrease in mileage.
Hemi31 is offline
post #8 of 28 Old 04-20-2014
Part Deux
Part Deux's Avatar
Brian,
With all due respect, A IV isn't going to lubricate cylinders. And even if you could come up with the physics to suggest it does, magical anti frictional compound isn't going to account for anything measurable. 10 HP is nothing. Outside air temp and barometric pressure could account for that much change, just by themselves.
Hemi31 is absolutely correct, racing fuel should have resulted in a much much larger HP change over 91 octane.
aka THO.R
Quote:
Originally Posted by 08 Stoned Charger View Post
I have a name for the 3 new mods...............Druken Purple Pirates!!!
Quote:
Originally Posted by Daytona606 View Post
American Muscle, like a pit bull. Big but not large, well defined, explosive power, in it till the end. The cat will give it go and zig and zag, but in the end the pit bull will always catch the cat the outcome is never good for the cat.
Part Deux is offline
post #9 of 28 Old 04-20-2014 Thread Starter
370 HEMI
Supporting Vendor
370 HEMI's Avatar
(Thread Starter)
MMT is the additive in these off the shelf boosters. MMT (Methyl cyclopentadienyl manganese tricarbonyl) is a metal that doesn't burn but plate in the cylinders leaving your plugs impossible to read and also leaves the residue to polish your cylinders. You would get the same effect on your cylinders by pouring jewlers rouge in the intake!
But for the sake of discussion, lets just assume it does do what you say.
As many chemists know, these products have a diminishing effect on higher-octane fuels. Adding the same product to 87-octane pump gas will produce a lot more gain than adding a bottle to 91-octane premium.
Too much of MMT will also damage emissions-control hardware, including spark plugs, injectors, up stream and down stream oxygen sensors and converters. This is why off-the-shelf additives have an emissions component safe formula and an off-road formula due to the concentration of MMT. Anyone who uses these additives really have is no point in using them in 87octane gas. The street version octane booster from your local parts store is a waste of time.
Now, using your example of 32 oz in 5 gallons to get 105 octane fuel with pump gas it is $20.95. $20.95 div by 5 = $4.19 per gallon. So 1 tank of Torco that damages the every day car would cost you an extra $80.45 to get 105 octane!!!
Wow and ACES IV did it for $6.76 PER TANK!!! So your Torco would treat one tank and the same price for the Torco would treat 11.9 tanks of gasoline using ACES IV!! So putting it another way, 192 gallons of ACES treated fuel is $67.60. 192 gallons of Torco treated fuel is $804.48. 1 gallon of ACES IV treats 770 gallons for $234.00 770 gallons of torco would be $3226.30. Anyone can see my point here!
The 598 by the way was 11.1 to 1 and the 110 was VP-110 leaded not oxygenated. So it did have the compression ratio to translate the race fuel and the street fuel.
As far as you using ACES IV, 1 eight oz bottle would start to clean your fuel system and your engine! If you are running the fuel trim fatter and you add ACES IV to it, it won't appear to do anything and actually hamper your economy both from being too rich and also from dropping carbon deposits into the mixture as well. We all know extra carbon hampers combustion.
We offered you an opportunity to openly bring your tuner and put your car on the dyno, add ACES IV and the dyno would prove it or disprove it with a 3rd party dynojet operator to be the referee.......FOR FREE! Again, you refused!
Brian
BND Automotive LLC
440-821-9040
370 HEMI is offline
post #10 of 28 Old 04-20-2014
Yuro
Senior Member
Yuro's Avatar
And he lives so close, id understand halfway cross country but same area?
Tough crowd
Yuro is offline
  Dodge Charger Forums > Vendors > BND Automotive
Related Threads
will 91 octane fuel get old ????? johnsondodge Performance Discussion/Modifications 8 04-18-2012 05:29 AM
ACES IV and Racing Fuel Ujokin2 BND Automotive 3 12-13-2010 08:54 PM
Octane, power, fuel additives and fuel mixture issues explained! 370 HEMI BND Automotive 3 03-09-2010 04:49 PM
ACES IV and 100 Octane Race Fuel Ujokin2 BND Automotive 1 02-09-2010 09:51 AM
ACES IV Fuel Catalys gcarrick Canada / Mexico 4 06-27-2009 01:30 PM
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
You may post new threads
You may post replies
