2015 and up Headlight Problems - Dodge Charger Forums
post #1 of 6 Old 3 Days Ago Thread Starter
T Woah
Junior Member
(Thread Starter)
Hey there. I’m a little taken aback at how expensive it is to replace a headlight bulb on a 2015. Per the dealer, a bulb replacement was $300 for an oem part. Got that replaced, and a couple weeks down the road, the circuit board of that headlight assembly is no good and is affecting my headlight by turning off and on as I drive. That requires a whole new headlight assembly for a mere $1100 just for the driver side and I’m at 70,000 miles.
Is there any aftermarket assemblies anyone would recommend that is nearly equivalent to oem?
T Woah is offline
post #2 of 6 Old 3 Days Ago
13Daytona1625
Senior Member
13Daytona1625's Avatar
Garage
I have a similar issue. Only when it rains though. My left side headlight will flicker when it rains and everything has been water proofed and what not. Going to install new HIDs including a new ballast to see if that is the issue. Havenít found any solutions what so ever though
13Daytona1625 is offline
post #3 of 6 Old 3 Days Ago
krautmaster
Senior Member
krautmaster's Avatar
Garage
Rock Auto sells them for $750
2016 SXT Plus
krautmaster is offline
post #4 of 6 Old 3 Days Ago
CtCarl
Senior Member
CtCarl's Avatar
If you don't mind used, car-part.com or lkqonline.com.
"Many true sports cars can be outrun by a powerful sedan." - Sir William Lyons, Chairman, British Leyland
CtCarl is offline
post #5 of 6 Old 3 Days Ago
Jerry-L
Senior Member
Jerry-L's Avatar
Garage
Quote:
Originally Posted by T Woah View Post
Hey there. Iím a little taken aback at how expensive it is to replace a headlight bulb on a 2015. Per the dealer, a bulb replacement was $300 for an oem part. Got that replaced, and a couple weeks down the road, the circuit board of that headlight assembly is no good and is affecting my headlight by turning off and on as I drive. That requires a whole new headlight assembly for a mere $1100 just for the driver side and Iím at 70,000 miles.
When you say, "headlight bulb", is that the fancy, newfangled HID kind, or is it the old style H7s or whatever?
Jerry
2017 Dodge Charger R/T
Jerry-L is offline
post #6 of 6 Old 3 Days Ago
13Daytona1625
Senior Member
Garage
Iím assuming heís taking HIDs. Doubt a halogen bulb from the dealer is $300
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
You may post new threads
You may post replies
