April 6 GPS Reset - Dodge Charger Forums
Audio - Alarms - Navigation - Electronics Member discussions about Charger audio, alarm and navigation systems and other electronics take place here
post #1 of 13 Old 4 Days Ago Thread Starter
2011RTMaxAWD
Junior Member
2011RTMaxAWD's Avatar
(Thread Starter)
April 6 GPS Reset
A word of warning to anyone that disconnects their battery at this point. I'm not sure what years are affected but the battery in my 2011 R/T died yesterday. Without warning and with no previous issues, I got in to start it and it just clicked. All of the electrical/electronic devices were behaving strangely. As the car is 8 years old I assumed the battery and bought a replacement. The car started fine and everything reset. I noticed the clock was 4 hours off. I was hoping it would pick up the GPS time and correct itself but when it did not do so after a couple of starts I began researching the situation and remembered seeing that there was a GPS reset (that supposedly affected devices greater than 10 years old). I see this happened 10 days prior to this incident. It would appear the you are likely to be unaffected until you lose battery power to the GPS. Once you do, it defaults to August of 1999. I can set the time manually but not the date. I'm not yet sure how bad this is but I'm not pleased as I expect the reply from Dodge is going to be buy a newer car. Maybe if enough folks complain they will release a software update? If anyone knows who it would be ideal to complain to I would appreciate that information.
Don't assume because you have not seen it that you are not affected and do not disconnect your battery for a test unless you are willing to live with the results that may never be fixed.
--Ok, can the firmware be updated on a 2011? I see many references to firmware such as CTP13 and higher. Can these be used to update, and if so, does anyone think it will fix the date issue?
2011RTMaxAWD is offline
post #2 of 13 Old 4 Days Ago
CtCarl
Senior Member
CtCarl's Avatar
What firmware are you running now?
"Many true sports cars can be outrun by a powerful sedan." - Sir William Lyons, Chairman, British Leyland
CtCarl is offline
post #3 of 13 Old 4 Days Ago Thread Starter
2011RTMaxAWD
Junior Member
(Thread Starter)
I assume the original as the Chrysler site has never published an official update on the site. The version says CTP 2011 followed by Software Version 3.10.
post #4 of 13 Old 4 Days Ago Thread Starter
2011RTMaxAWD
Junior Member
(Thread Starter)
Gonna answer my own question on the update as I went ahead and tried it. Looks like a no go. It spent a few minutes "validating update files" and then dumped out of it. Time and date still wrong.
post #5 of 13 Old 4 Days Ago
Bobw
Supporting Member
Garage
Quote:
Since this is a rollover issue, the firmware needing update is in the GPS receiver itself. Likely these vehicles depend on a NMEA data stream with correct UTC time - calculations for that are all done in the GPS receiver.
Any idea where the GPS antenna connects on these cars? The "radio" itself, or maybe some external module - like the original OnStar. If the receiver module can - the thing actually putting out the serial data - be gotten to, maybe there's hope of flashing it, or if you can't, maybe feed downstream with a different GPS module. Again, it's likely that updating the car "radio" doesn't flash the GPS.
Bobw is offline
post #6 of 13 Old 3 Days Ago
ericfother
Junior Member
I wonder if the car just needs enough time to download a new almanac from the satellites.
2008 Corvette 3LT, Z51, NPP.
2006 BMW 335i
2000 Camaro SS
1996 Camaro Z28
ericfother is offline
post #7 of 13 Old 3 Days Ago Thread Starter
2011RTMaxAWD
Junior Member
(Thread Starter)
Quote:
Not sure. I see nobody else complaining of this so I am still hoping there is a resolution.
post #8 of 13 Old 3 Days Ago
ToppCat
Senior Member
ToppCat is offline
post #9 of 13 Old 3 Days Ago Thread Starter
2011RTMaxAWD
Junior Member
(Thread Starter)
Quote:
Originally Posted by ToppCat View Post
Thanks for the suggestion. I may try that at some point but fear that it might cause additional problems and not solve this one.
post #10 of 13 Old 3 Days Ago
CtCarl
Senior Member
CtCarl's Avatar
Have you checked out this thread?
https://www.chargerforums.com/forums.../topics/236665
CtCarl is offline
  Dodge Charger Forums > Dodge Charger Discussion > Audio - Alarms - Navigation - Electronics
Related Threads
The Most Controversial thread....EVER Vito Charger Chat Lounge 123 11-18-2013 06:25 PM
On the hunt for a Daytona sickboy98tj General Charger Discussion 49 06-29-2011 01:10 PM
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
You may post new threads
You may post replies
