Hellcat won't shift into park. - Dodge Charger Forums
Charger SRT Hellcat Supercharged 6.2L Discussion Would you like the BLACK KEY or the RED KEY?
post #1 of 2 Old 02-12-2017 Thread Starter
hellkittyshan
Junior Member
(Thread Starter)
We had a few upgrades (new pulley) and took her for a spin this last weekend. When we got home, I couldn't shift into park and the P light on the shifter blinks. We had the codes checked and it's coming up with P0850. Any ideas? I will be taking her in, but they can't squeeze us in for two weeks.
hellkittyshan is offline
post #2 of 2 Old 02-13-2017
370 HEMI
Supporting Vendor
370 HEMI's Avatar
Here you go:
When is the code detected?
The signal of the park/neutral position (PNP) switch is not changed in the process of engine starting and driving.
Possible symptoms
Engine Light ON (or Service Engine Soon Warning Light)
P0850 Description
The transmission manual shift shaft switch assembly, also known as the Internal Mode Switch (IMS), is a sliding contact switch attached to the manual shift shaft inside the transmission case. The Park/Neutral Position (PNP) Switch is integrated into the IMS and connects to the Transmission Control Module (TCM) lead-frame through a short wire harness. The 5 inputs to the TCM from the transmission manual shift shaft switch assembly indicate the transmission gear selector lever position. This information is used for engine start enable, engine controls as well as determining the transmission shift patterns.
The state of each input is available for display on the scan tool. The five input parameters represented are Signal A, Signal B, Signal C, Signal P (Parity), and Signal N (Park/Neutral Start Signal). Park/Neutral Signal is sent from the Park/Neutral switch directly to the Engine Control Module (ECM) and is used for engine start enable. The Park/Neutral Signal circuit is not connected to the TCM internally; the circuit uses the TCM as a pass-through connector only.
The ECM Park/Neutral diagnostic monitors the Park/Neutral Signal circuit to detect Low voltage when the ECM expects to see High voltage and High voltage when the ECM expects to see Low voltage.
Read more: https://www.autocodes.com/p0850.html
Regards,
Brian
BND Automotive LLC
440-821-9040
www.bndautomotive.com
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
More Power, More Torque, Better MPGs - It's "Rocket Fuel For Your Car"
Custom Designed & Custom Blended "ALWAYS beats off the shelf brands"
Better cooling, better protection without all "The Gunk"
370 HEMI is offline
  Dodge Charger Forums > Dodge Charger SRT-8 > Charger SRT Hellcat Supercharged 6.2L Discussion
Engine Starts But Won't Go Out of Park DangerousCupcake Charger Problems/Assistance 9 09-10-2016 12:15 PM
Sometime I go into park and the key won't come out. Killmonr Charger Problems/Assistance 8 10-23-2015 11:32 AM
Car won't shift out of park?? christianjax Charger Problems/Assistance 28 08-22-2012 09:21 PM
Won't come out of Park! BMacM65 Charger Problems/Assistance 11 07-09-2012 11:19 AM
Won't shift out of park BSHAW27 Charger Problems/Assistance 5 07-21-2009 08:35 PM
Quick Reply
Message:
Options
Register Now
In order to be able to post messages on the Dodge Charger Forums forums, you must first register.
Please enter your desired user name, your email address and other required details in the form below.
User Name:
Password
Please enter a password for your user account. Note that passwords are case-sensitive.
Password:
Confirm Password:
Email Address
Please enter a valid email address for yourself.
Email Address:
OR
Log-in
User Tag List
Show Printable Version Show Printable Version
Email this Page Email this Page
Linear Mode Linear Mode
You may post new threads
You may post replies
For the best viewing experience please update your browser to Google Chrome
