Starting issues need help - Dodge Charger Forums
post #1 of 10 Old 1 Week Ago Thread Starter
Debodezine
Junior Member
Debodezine's Avatar
(Thread Starter)
Okay here's the deal this is basically my first Dodge product ever I've never even rode in a charger let alone drove 1 till now n I don't think I'd drive anything else it's fun as hell anyways it's a 2006 has the 3.5 liter when I got it I knew the water pump had a small leak and was probably going to need replaced so it's set at the house for a little while when I got the money n got the parts for the water pump I figured if I made sure I had fluid in the radiator I can make the one mile drive to my shop I was also low on gas as the low fuel light was on I get about halfway to the shop and as my luck would go I run out of gas are here I think is where I made my big mistake when I ran out of gas I was on top of an overpass in my town luckily it was at night no traffic but I ran out of gas in the spot where the car wouldn't roll forward and wouldn't roll back and I just wanted to get off the overpass so I did like you used to be able to do with the old cars crank on it it would start and run for 30 seconds and then die that you could do that about three times so I do get off the overpass had a friend come tow me the five blocks to the shop but it was weird turn the key on you can hear the fuel pump so naturally thought it was just out of gas about $10 worth of gas in the tank you can still hear the fuel pump cranks over but won't start only did this twice but you could shoot a little ether in and it would start and then die so what is the advice of a couple people I talk to you saying that the fuel pumps could still be working just not enough pressure I went ahead and I replaced both fuel pumps but before I replace them we have done quite a bit of cranking on it with with turning over because of the fuel pumps making noise now right before I change the fuel pumps a friend of mine wanted to hear the fuel pump come on and the motor turn over etcetera I went to turn it over and it wouldn't even crank almost like locked up that got me freaking out then somebody mentioned and I might add been working on cars most of my life usually in the body and paint aspect but I know a fair amount of mechanical this guy mentions hydrolock which I had never heard of I thought he lost his marbles watched few videos on YouTube about it and now I understand and it makes sense so I pulled my plugs and it still won't crank over after watching the videos on it I definitely don't want to keep cranking on it since it's not turning over and bend any valves or anything I do have a video of what it does when you crank it over and if I can figure out how to post it I will but I could definitely use some help on this thank you very much
Debodezine is offline
post #2 of 10 Old 1 Week Ago Thread Starter
Debodezine
Junior Member
Debodezine's Avatar
(Thread Starter)
Still trying fig how to do video
post #3 of 10 Old 1 Week Ago
krautmaster
Senior Member
krautmaster's Avatar
Garage
Water pump leak probably slowly softened up the timing belt until it stripped some of the teeth off, enough so that the camshafts no longer rotate but the crank shaft did until one or more of the pistons made contact with an open valve and locked the engine in that spot. Try rotating the crank backwards (counterclockwise while looking at the engine from the front) a bit, then pull off the front timing covers to see if the belt is intact and has any teeth left on it.
2016 SXT Plus
krautmaster is offline
post #4 of 10 Old 1 Week Ago Thread Starter
Debodezine
Junior Member
Debodezine's Avatar
(Thread Starter)
Okay thank you I was wondering about trying that are at least taking a look at it but since I got the water pump and new timing belt everything that comes with that kit still to install I was just about to post an update I've got all the plugs out and it still didn't turn over so does that mean that it wasn't hydrolocked
post #5 of 10 Old 1 Week Ago
krautmaster
Senior Member
Garage
Did you see coolant leaking onto the ground, or was it just disappearing from the coolant bottle? The 3.5 has been known to have the rubber gasket between the lower intake manifold and head crack over time and let coolant leak into the front or rear cylinder..a large enough leak will hydro lock the engine. Either way, you've got to tear into it a bit to find out what the problem is
I put over 300,000 miles on the 3.5 V6 in my 2001 Chrysler 300M, but I changed the timing belt & water pump and the intake gaskets every 75K.
ID:	274659   Click image for larger version
post #6 of 10 Old 1 Week Ago
djalbin
Senior Member
djalbin's Avatar
That's some curvature on the piston connecting rod.
2012 R/T with Road&Track and Super Track Pak, HHP 180F thermostat
DiabloSport i2 inTune with HemiFever 91-octane custom tune, Tazer
Airaid CAI, HHP Billet Tech catch can, Petty's Garage strut tower brace
Flowmaster 40-series mufflers, Magnaflow resonators (12" glasspacks)
22"x9.5" Versante Wheels (VE226A), 265/35ZR22 Dunlop Direzza DZ102 tires
djalbin is offline
post #7 of 10 Old 1 Week Ago Thread Starter
Debodezine
Junior Member
Debodezine's Avatar
(Thread Starter)
Yes i saw it leaking on the ground...as krautmaster suggested to. I tried to turn it over backwards with plugs out to no success so im thinking my next step is to go ahead n do the timing belt and water pump...i didnt mention earlier the spark plugs didnt appear wet but WOW were they ready to be changed...gap was .090ish lol
ID:	274663   Click image for larger version
post #8 of 10 Old 1 Week Ago
krautmaster
Senior Member
Garage
After you install the timing belt turn the engine over by hand four revolutions to see if the belt is truly in the right spots, then do a compression check on the cylinders before you put the plugs back in: you'll find out quickly if you bent a valve.
post #9 of 10 Old 1 Week Ago Thread Starter
Debodezine
Junior Member
Debodezine's Avatar
(Thread Starter)
Ok and if it has a bent valve will that cylinder be down on compression
post #10 of 10 Old 1 Week Ago
krautmaster
Senior Member
Garage
It will have no compression.
Related Threads
Issues when starting PhantomLover007 Charger Problems/Assistance 2 11-09-2011 09:43 PM
Starting Issues: Not cranking, cannot figure out MIAfinsfan13 Charger Problems/Assistance 9 11-24-2010 05:02 AM
Brake Issues. Links inside. ManGO Charger Problems/Assistance 4 10-10-2006 07:33 PM
Brake Rotor Issues?? xvulture Charger Problems/Assistance 5 04-04-2006 10:28 AM
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
You may post new threads
You may post replies
