Fuel Gauge Problems HELP - Dodge Charger Forums
post #1 of 2 Old 3 Days Ago Thread Starter
lhazze
Junior Member
(Thread Starter)
I have been having problems with my fuel gauge. I have a 2010 Dodge Charger SXT. I have checked the gauge on the dash and it seems to be functional. I have replaced both fuel pumps, the driver and passenger side. The gauge will show the incorrect level, if it's full it will show 1/4 tank. Need help badly. Ran out of parts to replace, haha.
I have now ran out of ideas. Any help will be appreciated. Thank you so much.
lhazze is offline
post #2 of 2 Old 2 Days Ago
djalbin
Senior Member
djalbin's Avatar
You can run the instrument cluster (IC) actuator test. The instrument cluster will perform a self-diagnostic test of the instrument cluster circuitry, the gauges and the indicators.
If you have the EVIC display ...
1. Begin the test with the ignition switch in the OFF position.
2. Depress the Electronic Vehicle Information Center (EVIC) Down/Scroll switch button on the left steering wheel spoke.
3. While still holding the Down/Scroll switch button depressed, turn the ignition switch to the ON position, but do not start the engine.
4. Release the Down/Scroll switch button.
5. The IC will simultaneously begin to illuminate all of the operational segments in the display unit and perform a bulb check of each operational LED unit indicator. The display segments and LED unit indicators remain illuminated as each gauge needle is swept to several calibration points and back.
6. The self-diagnostic test is now complete. The IC will automatically exit the self-diagnostic test mode and return to normal operation at the completion of the test.
If you don't have the EVIC display ....
1. Begin the test with the ignition switch in the Off position.
2. Depress the odometer/trip odometer switch button.
3. While still holding the odometer/trip odometer switch button depressed, turn the ignition switch to the On position, but do not start the engine.
4. Release the odometer/trip odometer switch button.
5. The instrument cluster will simultaneously begin to illuminate all the operational segments and perform a bulb check of each operational LED indicator. The display segments and LED indicators remain illuminated as each gauge needle is swept to several calibration points and back.
6. The actuator test is now completed. The instrument cluster will automatically exit the self-diagnostic mode and return to normal operation at the completion of the test.
2012 R/T with Road&Track and Super Track Pak, HHP 180F thermostat
DiabloSport i2 inTune with HemiFever 91-octane custom tune, Tazer
Airaid CAI, HHP Billet Tech catch can, Petty's Garage strut tower brace
Flowmaster 40-series mufflers, Magnaflow resonators (12" glasspacks)
22"x9.5" Versante Wheels (VE226A), 265/35ZR22 Dunlop Direzza DZ102 tires
djalbin is offline
Related Threads
Misfires and injector problems explained....... 370 HEMI BND Automotive 7 03-04-2019 09:40 AM
392 Fuel? MillDr General Charger Discussion 87 03-13-2018 04:57 PM
2015 RT P0300 Misfire Fault code samhane66 Charger Problems/Assistance 5 01-09-2018 09:27 PM
Fuel Gauge reading incorrect... iggys-amsoil Charger Problems/Assistance (2011 +) 5 08-21-2015 01:58 PM
Understanding symptoms of fuel injector issues...... 370 HEMI BND Automotive 3 12-20-2014 11:04 AM
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
You may post new threads
You may post replies
