Dodge Charger Part Numbers - Page 3 - Dodge Charger Forums
post #21 of 341 Old 01-12-2007
Junior
Senior Member
Junior's Avatar
Before I bought my Banana, I looked at fixing up an '06 R/T R&T with this stuff:
Daytona Honeycomb Grill kit - 82209978 - $39
Daytona Chin spoiler - 82209609 - $89
Daytona Rear Spoiler - 82209874 - $380
Daytona R/T Rear Badge - 4806323AA - $56.39
Daytona R/T Grill Badge - 4806324AA - $52.71
I, for one, would love to see prices on this list when they're available - how much harder would that make it?
Thanks for putting this together - great idea!
- Click above for my Hemi Registry page -
Junior is offline
post #22 of 341 Old 01-13-2007
AthlonDave
Senior Member
Quote:
Originally Posted by phenwick View Post
SRT Carpeted Cargo Mat 82209742
SRT Capeted Floor Mats 82209586
Anyone got the visor clip to add?
Sunvisor Clip as requested: 1EJ51BD1AA - Same part number for either side.
2007 Dodge Charger SE with Police Group (w/ 5.7L)! And yes, it is just a daily driver.
Mods So Far: Mopar fog lamps, Mopar cabin air filter, Mopar 6 disc MP3/CD radio, switches for front & rear wigwags, glove box lamp, MDS light, center console with cup holders.
AthlonDave is offline
post #23 of 341 Old 01-13-2007 Thread Starter
turbobuckeye
Supporting Member (Lifetime)
turbobuckeye's Avatar
Send a message via MSN to turbobuckeye Send a message via Yahoo to turbobuckeye Send a message via Skype™ to turbobuckeye
(Thread Starter)
I agree that prices would be helpful. It would probably be best to show MSRP rather than vendor/dealership prices on the main list. The vendor prices seem to vary quite a bit depending on if you got in on a group purchase or just purchased on your own. List both when you post and I think that would help too. I am open to suggestions . . . . . .
10th Annual LX & Beyond Nationals
National Trail Raceway - Columbus, OHIO - September 9, 2017
turbobuckeye is offline
post #24 of 341 Old 01-13-2007
AthlonDave
Senior Member
Quote:
I can help with most of the part numbers you need or desire being as I work at a Dodge/Chrysler/Jeep dealership parts department. Unfortunatly I can only give you Canadian list prices being as I am in Canada. I would guess that the majority of the members on this board reside in USA so therefore I can not be of much help with pricing. BUT if you do want CDN$ prices for your list I would be more than happy to help.
post #25 of 341 Old 01-17-2007
425hp
Senior Member
425hp's Avatar
06 SRT
4606839-AD Module Power (PCM) 407.10 list
5037636-AB Gasket Oil Pan 51.91
5037634-AA Pan Engine Oil 91.26
4792835-AA Pulley Idler 28.62
4896805-AC Alternator 379.50
4861660-AA Tensioner Belt 45.02
4892047-AA Bracket Alternator 1.65
5037542-AA Belt accessories 28.01
5037531-AC Cover Cylinder 54.47
5037739-AA Indicator Engine 5.25
5037660-AB Tube Engine 8.34
5037687-AB Pump Engine 57.65
5030076-AB Starter 148.75
5269870-AB Sensor Coolant 49.55
56041584-AF Sensor Camshaft 24.85
5149009-AA Sensor Crank 11.96
56041018-AD Sensor Map 121.36
56028563-AA Sensor Knock 103.48
56044777-AA Switch Oil Pressure 58.05
5149008-AA Sensor Temperature 56.36
4792838-AA Pump Water 121.36
5037394-AA Damper Crank 49.55
5290845-AB Pump Power Steer 264.00
4892093-AA Pulley Power 31.52
56029129-AB Coil Ignition 33.75
5149011-AA Capacitor Ignition 5.03
53021536-AC Housing Thermostat 2.50
5.7 Police
53022168-AA Plc Housing Thermo 11.02
4596561-AC Plc Hose Radiator 27.80
5037523-AA Plc Cooler engine oil 102.00
4596562-AC Plc Hose Radiator 39.45
C.
Silver 06 SRT-8
PPP 426ci.com Stroker, Track Warrior cam, half shafts, Mopar 392 Heads, Quaife LSD, Kooks LT headers, Dual Tbody intake, Corsa cat back, AFCO coilovers.
11.641 @ 116.805 (Best timeslip)
425hp is offline
post #26 of 341 Old 01-19-2007
titan
Senior Member
titan's Avatar
Anyone have the part number for the front fascia and the splash guard it connects to? Not the splash guard you remove to change the oil, the one in front of it with 10 screws or so that the fascia screws into.
2006 Charger R/T Midnight Blue Pearl
Heavily modified and my signature won't hold them all anymore.
titan is offline
post #27 of 341 Old 01-19-2007
RapidTransit
Senior Member
RapidTransit's Avatar
Does anyone have the part number for the bracket assembly that holds the PCM in place (bracket and 3 bolts) on an 06 Charger SRT-8?
2006 Silver Charger SRT-8
Billy Boat cat-back, aFe Stage II, B&G Stage II Flash
RapidTransit is offline
post #28 of 341 Old 01-24-2007
08MagRacer
Senior Member
08MagRacer's Avatar
anyone have part number for brilliant black grill no insert?
08MagRacer is offline
post #29 of 341 Old 01-28-2007
realorc
Senior Member
realorc's Avatar
https://www.chargerforums.com/forums/...ad.php?t=22075
Some parts list from repair invoice at dealer, shows list & unit price. Unit price isn't the lowest possible price.
4805872AB BEAM FRONT 113.00 110.00
4806179AD FASCIA FR 404.00 399.00
4805899AB ORNAMENT 20.50 20.10
4806165AE HEADLAMP L 229.00 225.00
4806164AE HEADLAMP R 229.00 225.00
4806180AB GRILLE RA 200.00 195.00
4805857AA LAMP FOG (Leftside?) 50.95 50.45
4806219AD LAMP SIDE (Leftside?)30.50 30.20
5065240AE C/MEMBER 55.85 54.70 (Radiator support - Lower tie bar)
5065524AE LATCH HOOD 32.20 31.50
Hood Prop
5065278AD Passenger side?
5065279AD Driver's side?
6507889AA studs (need two)
82208613 Roof Rack
82207308 Ski/Snowboard Roof Mount
82209792 Splash guards (front)
82209793 Splash guards (rear)
82208954 Slush mats (darkslate) I upgraded to WeatherTech FloorLiners, which is much better IMO.
5278655AB Locking gas cap
5163021AA Silver Steel Metallic Touch-up Paint
Found more part #s going through my papers.
04596496AA Sun Sensor
04685863AA Ignition Switch
04602348AD Head Lamp Switch - Auto
04649118AH Passenger Airbag
56044946AI Cluster Assy - Dodge 160 MPH
04602389AA Heated Seat Switch
55111030AF Temp Control - Auto
04692392AI Trans Control Module
05145216AC Owners Manual
  • Charger RT's Age: 3 years, 3 weeks
  • Gas Expense: $2869.41
  • Odometer Reading: 11635 miles
  • Overall Fuel Economy: 13.58MPG
realorc is offline
post #30 of 341 Old 01-28-2007
titan
Senior Member
titan's Avatar
Quote:
Some parts list from repair invoice at dealer, shows list & unit price. Unit price still looks like it's more than makeitmopar's prices.
shhhhh, we're not allowed to mention their incredibly low prices and outstanding customer service here because they are not a supporting vendor
titan is offline
Related Threads
Foose Part Numbers!!!!!!!!!!! bajagerry Wheels/Tires/Brakes/Suspension 2 04-10-2008 05:17 PM
SRT8 Hood - Part Numbers NEEDED! elcobra44 Exterior Discussion/Modifications 19 02-22-2007 08:38 PM
Can I get some part numbers? SmoothSL General Charger Discussion 5 01-29-2007 09:51 PM
Question on Novi part numbers? BurntOrange Wheels/Tires/Brakes/Suspension 0 08-25-2006 03:23 PM
May I please get Part Numbers for Mopar Exhust System and Mopar CAI for the 5.7 Hemi? danaM Performance Discussion/Modifications 3 04-05-2006 10:54 AM
Tags
catalog , part number
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
You may post new threads
You may post replies
