» Featured Product
» Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   Dodge Charger Forums > Supporting Vendors > Power Ported Performance
Please Visit our Site Sponsors
ChargerForums.com is the premier Dodge Charger forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
  #1
Old 11-14-2008, 02:06 PM
PPP-Tech's Avatar
PPP-Tech PPP-Tech is offline
Supporting Vendor
Lifetime Supporting Member
Anatomy of a PPP built shortblock.
The short block assembly is one of the most critical procedures in any engine build. No one understands that better than Power Ported Performance and ERL Performance. ERL Performance was founded with machinist and tool & die makers that have manufactured anything from precision gauges to jet engine parts. Their ability to utilize equipment, tooling and knowledge from these areas simply isn’t feasible for standard engine shops.
In an industry where close is good enough, PPP and ERL take a different approach. We believe the best method is a solid foundation. If the block and short block assembly is done right, then bolt on power upgrade can be added in the future. As your desire for performance increases, the money can be spent on the upgrade and not on the short block again.
All of our builds start with bare 6.1 block from Mopar. This is the same block that is running in excess of 800hp in other vehicles across the country. The crank is micropolished using a 15 micron belt, cleaned and checked using mitioyo inspection gages. With all of our blocks being align honed, the bearing bores for the crank are perfectly straight and sized to match the crank journal diameters. The align honing is a step that the majority of industry chooses to skip due to added costs.
All of the bearings are miked for thickness and matched to each journal/bore combination to achieve perfect clearance. No plastigage is used, due to inaccurate reading.
We offer several connecting rod choices depending on the intended use of the engine. No short cuts are taken due to the rod being the second highly stressed part in the engine (behind the valve spring). We offer the rods with different journal sizes, 1.850, 2.000, and 2.100, as well as .866 and .927 wrist pin options. The Carrillo rods are the top of the line offering and are the same as used in pro race cars. Each rod is inspected, re-torqued for repeatability, and sized for exact clearance.
Whether you choose a shelf stock or custom piston, we can provide it. Wiseco is our primary choice, but we will use any that you prefer. Each piston is miked, pin fitted and inspected. The cylinders are torque plate honed to fit each piston. Each piston ring is file-fitted to the cylinder it is going in for an exact ring gap to minimize leakage.
The assembly is done one at a time using dedicated tooling and inspected after each step. The same dedication goes into a street engine as goes into our race only engines. A documented blueprint sheet is provided with each assembled block. It is possible to throw the parts together and run for a while, just as you can drive on a bent rim if you put enough weights on it, but we choose to do it right the first time for maximum horsepower and durability which is also why we are one of very few companies to back our blocks with a 3 year/36,000 mile warranty.
PPP/ERL Performance shortblocks come standard with ARP main and head studs as well as Wiseco's top of the line GFX rings which include a 1.2mm Alloy steel gas nitrided postive twist top ring, a 1.2mm cast iron phosphate coated taper faced under hook second ring, and a 3mm 3-piece oil assembly stainless steel flex vent spacer and chrome faced rail Oil ring.
The pistons are 2618 alloy with strutted skirt designed to run as little as .004" clearance with excellent skirt wear and minimal noise or rock. The valve pockets are radiused for detonation resistance and increased flow around the valves. Anti-detonation grooves give the added benefit of keeping the top ring groove free of carbon. 3mm oil rings for better oil control and reduced friction for more horsepower. Pressure grooves for enhanced ring seal. Chrome Moly pins and spiralox (tool steel pins optional). Skirt coatings for lower friction, reduced noise, and superior life.
Below are some pictures of our shortblocks as well as pictures of the different pistons used in our standard offerings. While our shortblocks may cost more than the competition, in this industry, you very much so get what you pay for and we stand behind every single engine that goes out the door. Each of the 3 shortblocks carry the same 3 year/36,000 mile warranty.
Street/Strip PPP 392/426 shortblocks: $6136
Includes ARP Main/Head Studs, Block is decked and main journals are honed.
Race PPP 392/426 shortblocks: $7862
Adds Billet Main Caps, Tool Steel Wrist Pins, Gas-Ported Pistons with 14.5:1 CR, Partially filled concrete block.
Street/Strip Short Blocks
Race Hemi Short Blocks
__________________
FOR MORE INFO ABOUT OUR PRODUCTS, EMAIL PERFORMANCE@POWERPORTED.COM
  #2
Old 11-16-2008, 10:25 PM
Sublimeon22s's Avatar
Sublimeon22s Sublimeon22s is offline
Senior Member
Ill play you rock paper scissors for one, best of 3!
lol seriously though, that looks like one amazing piece of work
__________________
2007 Sublime Daytona #667 - FLXC member
now on 24" Status Symbols wrapped in Toyo 265/25/zr24 proxes 4s
  #3
Old 11-17-2008, 01:21 AM
BENISASPUD's Avatar
BENISASPUD BENISASPUD is offline
Senior Member
very beautiful engine. I wouldn't mind playing rock paper scissors for it. lol.
  #4
Old 11-20-2008, 08:51 AM
PPP-Tech's Avatar
Supporting Vendor
updated with pricing.
__________________
  #5
Old 11-20-2008, 09:08 AM
Gladiator's Avatar
Gladiator Gladiator is online now
Super Moderator
That is nice right there.
__________________
Are you not entertained? Are you not entertained? Is this not why you are here?
Tornado 2008 Brilliant Black SRT Options I,II,III 35% Tint, True Flow XDI, Flat Black BT Shifter and SRT Plate, SRT Third Brake Light, BT Catch Can, Tinted Tails, 5% Visor Strip, SRT Visor Disguisers, SRT Pedals, Quantum Blue & ACES IV, Vredestein 275/40/20, Sequential Turn Signals, 10,000K HID, AAC Color Shift Halos
  #6
Old 11-20-2008, 09:09 AM
zoomzoom1's Avatar
zoomzoom1 zoomzoom1 is offline
Senior Member
Thats sweet!!!!!!!!!
__________________
2006 Top Banana #3033-4000..Arrington Heads and Crazy Spartan Cam..LSA114.Mopar CAI, Mopar LT's w/Hi-flo's ..Mopar/Borla 125 Cat-bac.Custom Dyno-tuned by Brent at DTP Racing..360rwhp..380rwtqe..QB oil..Aces Fuel..P/S additive
2006 INFERNO RED SRT8..Mopar CAI 180stat..Custom Tuned by BRENT at DTP..402rwhp..398rwtqe
NUFF SAID
www.hr-mopar.info ...http://www.midatlanticmodernmopars.com
Roanoke Valley Mopar Club/Classic and Modern Mopars...http://www.roanokevalleymoparclub.webs.com
  #7
Old 11-20-2008, 09:53 AM
LongDriving's Avatar
LongDriving LongDriving is offline
Senior Member
I want one
__________________
2006 InfernoRed Charger R/T
HEMI - The Daddy of all Engines
"Some people are like slinkies. They seem worthless but still bring a smile to your face when pushed down a flight of stairs."
  #8
Old 11-20-2008, 04:25 PM
FlyByU's Avatar
FlyByU FlyByU is offline
Senior Member
These motors are the real deal.
__________________
| Arrington 426 | BFNY PERFORMANCE POWERED | Nitrous Outlet Direct Port | Paramount Performance Driveline | 10.28 @ 134 mph |
  #9
Old 12-05-2008, 08:06 AM
ping's Avatar
ping ping is offline
Senior Member
Send a message via Yahoo to ping
Anyone have an estimate on the install cost? I have the 5.7. I've just started reading about these, am completely clueless.
__________________
Ping
'07 RT Road/Track, born 05/01/07, 1am, 22x9 Vipers, 5% tint all around, resonators cut off, Air Raid CAI, Kenwood DDX-0719 with KNA-G510 navigation, ipod integration, xm portable unit
http://www.myspace.com/misterpotty
  #10
Old 12-05-2008, 08:20 AM
Hemi31's Avatar
Hemi31 Hemi31 is offline
Senior Member
Quote:
Most of the time I am sure you would be looking at $1k or less depending on where you have it done.
__________________
2006 Chrysler 300C
Arrington426,KWV2's,Hotchkis,Brembos,8.8 Paramount rear and HTC Nag1 and lots more.11.62@118.33.......so far.
Search this Thread:
Advanced Search
You may not post new threads
You may not post replies
Similar Threads
PPP Stage III Heads and PPP Custom Grind Cam - PICTURES! RandysWay Power Ported Performance 5 05-27-2008 10:21 AM
The Anatomy of Power: The Story of Hemi31 installed Sidewinder RR/TT Performance Discussion/Modifications 11 04-01-2008 08:29 AM
Pics of PPP 5.7/392 Shortblock PPP-Tech Performance Discussion/Modifications 37 03-05-2008 02:54 PM
Traction issues with a PPP built truck! PPP-Tech Power Ported Performance 8 02-10-2008 10:39 PM
PPP Shortblock info! PPP-Tech Power Ported Performance 3 12-08-2007 09:09 PM
Powered by vBulletin®. Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© AutoGuide
