Help - Air Intake Sensor Removal - Dodge Charger Forums
Performance Discussion/Modifications Discuss any performance modification in this section.
post #1 of 18 Old 11-11-2008, 06:45 AM Thread Starter
TROOPER
Senior Member
TROOPER's Avatar
(Thread Starter)
Question Help - Air Intake Sensor Removal
Howdy,
Any tips or pictures, on the best way to remove the air intake sensor.
I recall reading another thread, saying it was a real ***** to do.
It's on a R/T 5.7L by the way.
Cheers
NEW - '07 Chevy TrailBlazer
SOLD - '08 Charger R/T - 5.7L V8 HEMI - Black
TROOPER is offline
post #2 of 18 Old 11-11-2008, 09:03 AM
NummThumz
Senior Member
NummThumz's Avatar
Removing and replacing the sensor was by far the hardest part of my CAI install. After the fact, someone gave me the advice of using rubbing alcohol to lubricate the rubber grommet. The moisture will help, but because it is alcohol, it will evaporate quickly. Hope that helps.
2007 R/T with Road & Track- Steel Blue Gone but not forgotten...
2016 Scat Pack- Jazz Blue
NummThumz is offline
post #3 of 18 Old 11-11-2008, 09:34 AM
zoomzoom1
Supporting Member (Lifetime)
zoomzoom1's Avatar
My Tec uses a light ncoating on the sensor, oil that is....
2006 Top Banana #3033-4000..Arrington Heads and Crazy Spartan Cam..LSA114.Mopar CAI, Mopar LT's w/Hi-flo's ..Mopar/Borla 125 Cat-bac. EForce supercharger by Edelbrock Mopar stage one Lowering springs, KONI STR shocks.Custom Dyno-tuned by Brent at DTP Racing..500rwhp..490rwtqe..QB oil..Aces Fuel..P/S additive'
2006 INFERNO RED SRT8..Mopar CAI 180stat..Custom Tuned by BRENT at DTP..402rwhp..398rwtqe
Roanoke Valley Mopar Club/Classic and Modern Mopars...
zoomzoom1 is offline
post #4 of 18 Old 11-11-2008, 09:43 AM
Gladiator
Super Moderator
Gladiator's Avatar
Forgive my stupidity but if you are talking about the sensor that is connected to the air intake, I just reached up in there and pushed while I pulled. I wiggled it around a bit and it came right out.
Are you not entertained? Are you not entertained? Is this not why you are here?
Gladiator is offline
post #5 of 18 Old 11-11-2008, 10:19 AM
Mj007
Member
Mj007's Avatar
mine wouldnt come out for anything...i eventually took two putty spreader things ( anything flat and wide with a handle would work) and used them to pry the b*tch out. I was 30 seconds from just cutting it out of the stock tube. getting it in the afe tube was even worse. I had to make the hole bigger with a file and it was still extremely tight. ( if you have to do that make sure you get all the shavings out of the tube).. I have a 3.5L though.
Mj007 is offline
post #6 of 18 Old 11-11-2008, 04:04 PM
Bytor014
Member
Dish soap
Make life easy! Dish soap and a little elbow grease!
Bytor014 is offline
post #7 of 18 Old 11-11-2008, 04:15 PM
ChargerRTRT
Senior Member
ChargerRTRT's Avatar
Yup... dish soap is the best... it rinses and cleans up easily. PLUS oil will break down rubber and rubbing alc will dry it out.
ChargerRTRT is offline
post #8 of 18 Old 11-11-2008, 04:21 PM
cmooremax
Senior Member
cmooremax's Avatar
i never had a problem getting it out, just in. i just spit on it and worked it in. sounds like a porno i know but it went in lol
TOP BANANA 1605-4000 AND LOVIN' IT 322 RWHP 362 fptq
MOD's: mopar cai, hood struts, ebc red pads, ebc slotted & drilled rotors, DMH electric cut-outs, Diablo Trinity, Mopower chin spoiler, 22" Giovanna Essen, Nitto 420's 265-30-22 up front, 295-30-22 in the rear, BT nose emblem, tinted tails
waiting for good weather: 195 thermo, Arrington TB, stage 4 ported heads, CC-607 cam, BT valve covers, and BT coil pack covers, more to come!
cmooremax is offline
post #9 of 18 Old 11-11-2008, 04:59 PM
zoomzoom1
zoomzoom1's Avatar
Talking
Quote:
Yeah Right...Charger porno at that!!!!
post #10 of 18 Old 11-12-2008, 06:22 AM Thread Starter
TROOPER
Senior Member
TROOPER's Avatar
(Thread Starter)
I just though the same thing, before I finished reading your statement
Some good advice anyway guys, cheers
TROOPER is offline
  Dodge Charger Forums > Dodge Charger Discussion > Performance Discussion/Modifications
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Air Intake Sensor for CAI question Phanta5m Performance Discussion/Modifications 6 08-17-2008 11:17 PM
intake air temp sensor connector question robryche Performance Discussion/Modifications 1 04-22-2008 05:59 PM
Help! Intake Air Temp Sensor pikapp Performance Discussion/Modifications 8 03-10-2008 06:26 PM
Cant get intake air sensor in CAI jsj098 Performance Discussion/Modifications 21 05-04-2007 05:46 AM
Where Is The Iat(intake Air Temperature) Sensor Located On 2007 Dodge Charger? BLACKKNIGHT Performance Discussion/Modifications 5 03-04-2007 10:18 AM
You may post new threads
You may post replies
