EVIC Easter Egg.....? - Dodge Charger Forums
General Charger Discussion General Discussion about the Dodge Charger.
post #1 of 15 Old 03-01-2006, 12:17 AM Thread Starter
c-Dub
Member
(Thread Starter)
Red face EVIC Easter Egg.....?
OK so today a buddy I work with tells me to hold the "Music" and "North" buttons on the steering wheel at the same time for about 5 seconds and I'll get a whole new set of menu's.
I've done it and it's TRUE. So why can't I find any mention of it anywhere in here? Does anyone have a map that can tell me what some of these things refer to?
It has some very cool info. including actual oil psi, % of throttle position, tachometer etc, but it also has some settings that aren't so obvious....
It references "TempAVG" which you can adjust between -26 degrees and 131 degrees.
Next line says TempRAW and seems to be displaying the outside temp.
Next line reads "0 11 H" (???)
The next sceen that is vague:
First Line "MinL=185 MinR=194" (Those are my readings)
Second Line "Lt= 40 Rt= 45" (my #'s again)
Third Line "19g Avg= 84 (my #'s again)
The last screen that needs explanation reads:
VTA trig: None
Wake: LF Door
168 (This # can be changed) Lgt:238 (this # is static...or atleast I don't see how to change it...)
HBduty: 0%
Black SRT8 Option Groups I, II, and III. Techco Supercharger, Indy-Ported/polished Heads w/Titanimum Retainers, 4130 Push Rods, and a Comp Cams XFI 268 cam. Diablo Sport with Custom tune by Techco and E-Cut Outs (just for fun).
c-Dub is offline
post #2 of 15 Old 03-01-2006, 04:41 AM
GLHS837
Super Moderator
GLHS837's Avatar
Re: EVIC Easter Egg.....?
http://www.chargerforums.com/forums/...read.php?t=293
"For a mechanic, you seem to do an excessive amount of thinking."
―C-3PO, to R2-D2
GLHS837 is offline
post #3 of 15 Old 03-02-2006, 12:08 AM Thread Starter
c-Dub
Member
(Thread Starter)
Ahhhhh........You Rock! Thanks.
Now I can sleep.
c-Dub is offline
post #4 of 15 Old 04-20-2006, 07:04 PM
Fedexjetmx
Senior Member
Fedexjetmx's Avatar
VTA trig: None
Wake: LF Door
HBduty: 0%
I've been trying to find out what the last line is.
"HBDuty 0%" ?
havent found anything it the in the search.
3058 of 4000 T/B Daytona The wife's "grandma car"yyaaaa right.
If its got tits or wheels your gonna have trouble with it eventually
Fedexjetmx is offline
post #5 of 15 Old 03-04-2014, 08:41 PM
fivethirteen
Member
fivethirteen's Avatar
Quote:
"HBDuty 0%" ?
As far as I know, this is the correct information.
fivethirteen is offline
post #6 of 15 Old 03-04-2014, 09:33 PM
Ddaddy
Supporting Member (Lifetime)
Ddaddy's Avatar
Garage
HBduty - Numerical Percentage
Shows the current intensity level of the SmartBeam system, 0% = off, 100% = full high beams
I have never found this to be true. I have never had the so-called "SmartBeam" system engage. My thought is this was programmed into the original software but it was never included as an actual feature. I have tested it numerous times since the car was new but never found a condition in which it actually deploys.
Mine has never read anything but 0%.
2006 Charger SRT-8
1969 Dart GTS 340
2012 Chrysler 300C Hemi
All V8 Mopars!
Ddaddy is offline
post #7 of 15 Old 03-04-2014, 10:11 PM
mnunes
mnunes's Avatar
I thought I read somewhere that HBDuty% indicates the level that the high beams are used at for daytime running lights. If you don't have DRL enabled, I would think it's always 0%.
2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
2015 Durango R/T - Aug 2015 ----->
mnunes is offline
post #8 of 15 Old 03-04-2014, 10:20 PM
fivethirteen
Member
Quote:
That's my understanding as well, hence my disclaimer (as far as I know). I vote DDaddy as guinea pig to roll into the dealership and have it turned on and back off... :-)
post #9 of 15 Old 03-04-2014, 10:25 PM
Ddaddy
Ddaddy's Avatar
Garage
Quote:
Yeah, I'll get right on that...second Tuesday of next week.
Ddaddy is offline
post #10 of 15 Old 03-05-2014, 08:07 PM
GLHS837
Super Moderator
GLHS837's Avatar
I think SmartBeam was strictly a 300C option back then, it has nothing to do with DRLs, it's the automatic system that turns highbeams on and off as needed.
http://www.worldcarfans.com/10512228...ritage-edition
Quote:
The SmartBeam intelligent headlamp system is a premium, sophisticated aid for nighttime driving. It automatically and quickly adjusts high-beam brightness and intensity, depending on the surrounding nighttime light sources. The 2006 Chrysler 300C Heritage Edition is the first, and only, Chrysler vehicle offering this technology in 2006.
GLHS837 is offline
  Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
changing non evic guage cluster with evic. POSSIBLE??? crazylikeacharger Interior Discussion/Modifications 13 02-28-2008 09:05 AM
Easter Egg Hunt is on - RockBlocker RockBlocker General Charger Discussion 4 04-04-2006 09:29 AM
Easter Egg Hunt for Charger Members RockBlocker General Charger Discussion 52 03-31-2006 09:00 PM
What's Good To Take Egg Spot's Off BLKSE#75 Charger Problems/Assistance 12 03-09-2006 06:51 PM
Anyone Want A Scrambled Egg? nCHARGE Off-Topic 19 01-07-2006 09:44 AM
You may post new threads
You may post replies
