STS Twin Turbo System - 5.7 and 6.1 - Dodge Charger Forums
Forced Induction Discussion Any Turbo or Supercharger related questions and or comments.
post #1 of 38 Old 10-15-2008, 02:24 PM Thread Starter
tbyrne
Banned User
(Thread Starter)
We are pleased to announce the release of the STS Twin Turbo System for the Chrysler/Dodge Hemi LX platform vehicles!
The 5.7L and 6.1L Dodge Charger, Chrysler 300C, and Dodge Magnum from model years 2005 to 2008 are ready to be unleashed!
With stock engines and a conservative 5-6 pounds of boost, you can expect approximately 540 Horsepower and 620 ft-lb Torque after installing their patented rear-mount turbo system on your 5.7L! That is a 60% increase in both horsepower and torque!
Your 6.1L SRT8 will see approximately 630 Horsepower and 650 ft-lb Torque after the install!
Have a built engine? The "Twins" have plenty more power to give!
*Horsepower numbers are flywheel
Video on YouTube - http://www.youtube.com/watch?v=XiJZxBOwJZ8
Benefits of STS Remote-Mounted Turbochargers -
Lower underhood temperatures. No need to worry about melting wires, hoses, or other engine components, as with a front-mounted turbo.
Ease of installation. STS turbo systems can be installed in about 8 hours with standard tools and average mechanical ability.
Cooler oil to the turbo. Cool oil is better for both the turbo and engine.
Performance Sound. The turbo acts as a muffler and sounds like an aftermarket performance muffler. Turbo spool and rushing air from the blow-off valve make a unique sound that will turn heads!
No need for major modifications to your vehicle. STS systems are designed to "bolt-on" to factory mounts.
Increased gas mileage. Unlike a belt driven supercharger, the turbo utilizes "wasted" energy leaving your tailpipe. Most of our customers get 1-3 mpg increase in gas mileage compared to their original stock mpg numbers.
Converts back to stock in about an hour.
More room under the hood. Future repair work or modifications will not require the expense of removing the turbo system to allow access to engine components.
Lowest Intake Air Temps. Low IAT's equate to more horsepower per pound of boost than any other forced induction option. STS intake piping provides built-in intercooling. Add the optional intercooler, and IAT's drop even further.
Approximately 500F lower turbo temperatures. Eliminates the need for a turbo-timer, which allows the engine to run after the car is shut off in order to cool down the turbo and prevent oil and bearing damage.
Denser exhaust gasses drive the turbo turbine wheel more efficiently.
Turbo is exposed to ambient air rather than underhood air. Allows for better cooling of turbo components.
No need for expensive headers, mufflers, or exhaust systems.
Turbo is closer to the tail pipe outlet. Provides a better pressure differential across the turbine wheel which promotes better flow across turbine.
Better weight transfer. Increases traction because the bulk of system is mounted in rear of vehicle rather than up front.
Less noise and heat in the passenger compartment.
Tom
tbyrne is offline
post #2 of 38 Old 10-15-2008, 02:33 PM
dustinc22
Senior Member
dustinc22's Avatar
Looks cool but man that sound is just to much. Maybe it is just the video but man that is an embarrassing sound.
Are their any kind of over time test results? Miles with system, etc...
-- 2007 Charger R/T Road and Track package --
2007 R/T Road and Track (Tint 35%, Blinker Mod, DeMolded Sides, Splash Guards, Custom Painted Yellow Badges and calipers, Mopar CAI, painted engine cover, GTS rain guards, Tinted Tails & Side Markers, R1 Rotors, Danko DeepDisch Grille, Blastn Bobs...)
dustinc22 is offline
post #3 of 38 Old 10-15-2008, 04:39 PM
dustinc22
Senior Member
dustinc22's Avatar
No one has anything to say about this.
post #4 of 38 Old 10-15-2008, 04:42 PM
crazylikeacharger
Senior Member
crazylikeacharger's Avatar
Send a message via AIM to crazylikeacharger Send a message via Yahoo to crazylikeacharger
yeah the sound is too ricey like. if the whistle was more like a diesel truck then it might be a little better
Too many mods to list now. reached the limit of this forum signature!!!!
crazylikeacharger is offline
post #5 of 38 Old 10-15-2008, 05:32 PM
RitzRT
Senior Member
RitzRT's Avatar
Quote:
It does sound like a party whistle. People will be waiting to see how many clowns come pouring out of the doors when you stop.
No thanks.
Formerly had 2006 Charger R/T
Cool Vanilla <-- rarest color
Mods So Far: Hood struts, Cabin Air Filter
RitzRT is offline
post #6 of 38 Old 10-15-2008, 05:42 PM Thread Starter
tbyrne
Banned User
(Thread Starter)
I've sold quite a few of these for other vehicles and used one on an '04 GTO (LS1 motor). They work very well! Alot of import owners go with a turbo instead of a supercharger so people associate this with those cars. I think the turbo sounds better in person. The video doesn't really do it justice.
Tom
tbyrne is offline
post #7 of 38 Old 10-15-2008, 05:57 PM
sharp charge
Senior Member
sharp charge's Avatar
Who cares how the turbo sounds as long as it performs. How much??
2011 Dodge Ram Outdoorsman. Formerly a 2007 Dodge Charger R/T
sharp charge is offline
post #8 of 38 Old 10-15-2008, 06:00 PM
KStryker
Senior Member
KStryker's Avatar
Send a message via MSN to KStryker Send a message via Yahoo to KStryker
LOL, that sound would get annoying fast...but like sharp said....The performance is main deal breaker!
(Vehicle Totaled on 4/10/2015)
Brilliant Black 2010 Charger SRT8
Appearance: CBD CF SRT8 Hood
Performance: AirRaid CAI, Diablo Predator Perf CAI 93
KStryker is offline
post #9 of 38 Old 10-15-2008, 06:01 PM
dustinc22
Senior Member
dustinc22's Avatar
Quote:
Tom
There is also clip of a challenger with this set up but it is on a dyno and you can barely here the whistle.
http://www.youtube.com/watch?v=vzGh6ERXcxo
http://www.youtube.com/watch?v=Mt1NLyRbmIA
Would you say it is more like the 6.1 sound and the cameras mic is just very sensitive to high pitch? Or is the 5.7 sound much different?
Thanks
post #10 of 38 Old 10-15-2008, 07:06 PM
crazylikeacharger
Senior Member
im in with dustin on that is the sound of the 6.1 and 5.7 the same and i would like to see one in person. LX and BEYOND MAYBE??? GUYS????
  Dodge Charger Forums > Dodge Charger Discussion > Forced Induction Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
STS Twin Turbo System - 5.7 and 6.1 tbyrne Performance Discussion/Modifications 24 09-22-2008 02:43 PM
STS Turbo?? Charger Mike V6 Specific Discussion 0 08-06-2008 05:32 PM
Do they have a rear twin turbo system ?? xaoxaoo Performance Discussion/Modifications 7 08-13-2007 08:51 AM
STS Turbo anyone? LosingSleep Charger SRT-8 Discussion 4 05-25-2006 02:29 PM
You may post new threads
You may post replies
