throttle position sensor - Dodge Charger Forums
post #1 of 10 Old 09-13-2008, 10:31 AM Thread Starter
SRT 666
Supporting Member (Lifetime)
SRT 666's Avatar
(Thread Starter)
Anyone ever encounter a problem with this sensor getting wet when you wash? I am on my 2nd one in a 2 month period.Dodge told me to wash the motor differently. Would water be coming in through the filter or around the throttle body and or spacer? thanks.
SRT 666 is offline
post #2 of 10 Old 09-13-2008, 10:33 AM
sound&security
Senior Member
sound&security's Avatar
i never have seen that problem-BUT-are you washing the h3ll out of the front of the motor by the trottle??? maybe you should stop hosing down that part of the motor.
sound&security is offline
post #3 of 10 Old 09-13-2008, 10:50 AM Thread Starter
SRT 666
SRT 666's Avatar
(Thread Starter)
I dont even know what that is? But ya i am gonna be a little more carefull with the pressure i think! Thanks though.
SRT 666 is offline
post #4 of 10 Old 09-13-2008, 11:12 AM
mnunes
mnunes's Avatar
How much pressure are you using? I've only used the garden hose with a regular nozzle, not a pressure washer. I also wrap the air filter in plastic to prevent it from getting wet and letting any water in.
2006 Charger R/T w/ R&T - Sept 2005-Aug 2015
2015 Durango R/T - Aug 2015 ----->
mnunes is offline
post #5 of 10 Old 09-13-2008, 11:15 AM
Phanta5m
Phanta5m's Avatar
Quote:
same here... and i only use the mist selector on the water nozzle
Phanta5m is offline
post #6 of 10 Old 09-13-2008, 11:29 AM Thread Starter
SRT 666
SRT 666's Avatar
(Thread Starter)
Well, this will sound bad but we have a 2800psi karcher, but i dont go that close.What about gunk? spray that on the motor and a stream rinse off? I think i will do what you guys are doing. Cover the filter with a bag.It does a great job on the trucks with the zep(blast away) soap.That soap works great on the undercarriage of the car as well.Frame looks brand new.I like clean vehicles!
SRT 666 is offline
post #7 of 10 Old 09-13-2008, 11:40 AM
mnunes
mnunes's Avatar
Yeah, that pressure washer is going to get lots of really tiny droplets of water blasted into places that a hose won't. I'm really glad you're not using a steam cleaner 'cause that's even worse about getting moisture into all the little electrical connectors.
My engine cleaning procedure.
With the engine cool, I spray on some Simple Green and let it sit for a few minutes. Then I use the hose and rinse it all off. If there's anything stubborn that I can reach, I use a little more Simple Green and a cloth, then rinse again. Wipre dry and spray on Stoner's Trim Shine (other members use tire dressing, which works great, too). Finally, run the engine for a few minutes (until warm) to dry off anything that I couldn't reach.
mnunes is offline
post #8 of 10 Old 09-13-2008, 11:45 AM
Phanta5m
Phanta5m's Avatar
nice... that system seems to work the best for me too
Phanta5m is offline
post #9 of 10 Old 09-13-2008, 11:51 AM Thread Starter
SRT 666
SRT 666's Avatar
(Thread Starter)
Simple green works wonders in so many applications.Gunk smells so much like diesel fuel and you can smell it through your fresh air intake.We use it on the trucks, mainly on the frames to remove grease from u joints before a show.Cheaper way is 2 gallons worth of diesel and a few rags and crawl under the car and start wiping!
SRT 666 is offline
post #10 of 10 Old 09-14-2008, 02:38 PM
rodneyiii
Senior Member
rodneyiii's Avatar
You guys are asking for trouble by repeatedly washing your engines, especially with high pressure sprayers. What are you having to remove? A spotless engine is a bad trade-off for having to replace water-damaged parts. I bet the aluminum stuff is corroded already.
2006 Inferno Red SRT8 with groups I, II, Sunroof, K&N drop-in filter, Auto-dim mirror, Jet-180 T-stat, Predator, 300 SRT struts/springs, Chally SRT wheels.
Born 6-21-06, Home 4-26-10. 1/4 mile - 12.989 @ 108.78 in street trim. Traded 10-19-2012.
2006 Inferno Red R/T with R&T Born 8-12-05, Home 8-25-05, Sold 8-9-10.
rodneyiii is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Throttle Position Take 2 nCHARGE Performance Discussion/Modifications 134 04-03-2015 06:08 PM
Predator shows 76% throttle plate position Jonny V6 Specific Discussion 1 05-12-2008 06:06 PM
throttle postion sensor??? wishing for hemi Performance Discussion/Modifications 0 02-16-2008 10:23 AM
Throttle Position Reset? ducvw2004 Charger Problems/Assistance 12 05-09-2007 01:48 PM
Throttle Position CONFUSION!!! AZCHARGER Performance Discussion/Modifications 18 08-24-2006 10:24 PM
You may post new threads
You may post replies
