2008: Problem removing key from ignition - Dodge Charger Forums
post #1 of 16 Old 07-18-2008, 05:00 PM Thread Starter
Anguish
Supporting Member (Lifetime)
Anguish's Avatar
(Thread Starter)
I've got a 2008 with the not-really-a-key key. Since I got the car, I've had three instances wherein I've parked the car, put it into park, and shut it off but then wasn't able to remove the key from the hole. It seems the key won't rotate all the way to its normal release point, which is about 45 degrees counter-clockwise of vertical. Instead, it goes about half way.
I've tried the obvious; jiggling repeatedly, stomping on the brake pedal, starting and stopping the car, putting it into gear and back into park, and moving the car a few feet forwards then re-parking, and rotating the steering wheel.
Twice, some minor effort and combination of the above got the key to release. This morning none of that worked. I eventually drove around the block and lo and behold, the key released normally. It's behaved normally ever since.
The question is: am I doing something wrong? I mean, I've seen cars where you can only release the key if your foot is on the brake, or that have a fit if the steering wheel is in the wrong position, but this doesn't seem consistent.
Any hints or suggestions before I bring this to the cringe dealer?
2008 Brilliant Black R/T R&T w/SRT body.114 LSA cam. Borla 125 catback. JBA shorty headers. Aluminum rear-window louvers, custom vented fenders. Front & rear LED halos, Tinted tails. Toyo Proxes 4 245 front 275 rear.
Billet Tech: BSG62 hood & tail emblems, wheel-centers, visor covers, fuse box cover. Custom CHARGER badge. Shifter plate. Frankintake. Satin door locks & pull-rings, engine kit, coil-pack & valve covers.
Anguish is offline
post #2 of 16 Old 07-18-2008, 10:36 PM
The Nug
Senior Member
The Nug's Avatar
I too have the 2008 with the key that isn't really a key. I've not experienced any problems like what you describe, but I will describe my exact "exit procedure" for you, which you can try to see if it is in fact something you're doing wrong.
Here's what I do:
On inclines: Stop vehicle, hold brake, apply parking brake, shift to neutral, release brake, reapply brake, shift to park, rotate and remove key.
Flat surface: Stop vehicle, hold brake, park, release brake, rotate and remove key.
Those are the only two ways I've ever parked the vehicle and I've never had a problem releasing the key.
EDIT: Also, from what I've noticed with mine, the steering wheel lock seems to have no relation to the key. My guess is the steering wheel lock is completely computer controlled. Then again, I could be an idiot, and be wrong.
The Nug is offline
post #3 of 16 Old 07-19-2008, 08:24 PM Thread Starter
Anguish
Anguish's Avatar
(Thread Starter)
Quote:
Here's what I do:
Thanks for the input. I live in a really flat place, so I've not used a parking brake in 20 years of driving. My exit procedure is identical to your flat egress. Shrug. I'll keep an eye on it and file it as a warranty claim if I need. So far it's about once every other week. That's a lot of start/stop cycles for me.
Anguish is offline
post #4 of 16 Old 07-19-2008, 08:37 PM
Phanta5m
Phanta5m's Avatar
i just got my 08 today... i've never had a key like this... hope your situation doesn't get any worst
Phanta5m is offline
post #5 of 16 Old 07-19-2008, 08:45 PM
TBird100636
Senior Member
TBird100636's Avatar
Cool
You may have an issue with the WIN. Unfortunately, something is blocking me from saving STAR Online cases. So here is a copy and paste.
Case Number K64849105
Vehicle Issue The ignition is stuck in Accessory and cannot be rotated to the off position.
Year 2008
Model LX - 300 | LX - Magnum | WK - Grand Cherokee | LX - Charger | XK - Commander | RT - Caravan / Town and Country
Category Customer Concern (No DTCs)
System or Component Ignition Switch | FOB Integrated Key (FOBIK)
Symptom Stuck | Will Not Turn Off
Condition Verification Yes - Continuously
Case Verification WIN module equipped vehicles.
Recommendation Using the StarSCAN or StarMOBILE read the status of the Gated Park Switch while the ignition is stuck in Accessory.
Make sure the shifter is fully in the PARK position.
If the input is FALSE the shifter or wiring should be examined as the root cause.
If the input is TRUE the WIN module should be replaced for a faulty internal solenoid.
Modification Date 05/07/08 12:23 PM
2011 Dodge Charger R/T Plus AWD- Redline-
2006 Dodge Charger R/T- Inferno Red- Gone-
TBird100636 is offline
post #6 of 16 Old 07-19-2008, 08:52 PM
TBird100636
Senior Member
Exclamation
Here's what I do:
These vehicles (2005-present LX Magnum, 300, and Chargers do not have a steering column lock. According to Chrysler, it was not needed for federal compliance, and with a brake/shift interlock a column lock was considered redundant.
post #7 of 16 Old 07-19-2008, 11:09 PM
ChrisJ08
Senior Member
ChrisJ08's Avatar
Quote:
Its essentially a fat Mercedes Benz Key.
I compared it to a friends C350 and ours is chrome-less and fatter but the shape, and the valet key is the same - just larger.
BTW its called a "FOBIK"
08 Charger SRT8
-Options I, II, III, Side Airbags, HIDs, SRT Design Wheels
-Airaid CAI w/hoodscoop attachment, Predator 91 Tune, Limo tint, Grant Steering Wheel
"Vorsprung durch glaube"
ChrisJ08 is offline
post #8 of 16 Old 07-20-2008, 10:43 AM
sniferscot
Senior Member
sniferscot's Avatar
Send a message via AIM to sniferscot
When I was buying My 08 I test drove a different color and upon returning to the lot after my drive I could not get the key out.Neither could the salesman. so the car was taken back to a service bay.No luck there either. Guess this was a good reason I did not buy a Torred charger.
2008 Cool Vanilla SE Mods ...rear spoiler, fog lights ,35/20 window tint, Daytona exhaust w/suitcase removed.Honeycomb grill GTS Ventshades.
sniferscot is offline
post #9 of 16 Old 07-20-2008, 04:07 PM Thread Starter
Anguish
Anguish's Avatar
(Thread Starter)
Year 2008
Thanks for the input. Obviously any and all information is ammunition. Sadly my condition is highly sporadic, not continuous. So far it's been possible to clear the condition. I'm going to let it happen once or twice more to see if I can gather more specific means of clearing it before filing a warranty claim.
Anguish is offline
post #10 of 16 Old 07-20-2008, 04:54 PM
B5976
Member
B5976's Avatar
Never had this problem with my Bee...My 'not key' almost feels loose in the slot. Hope I don't get this problem as I'm a volunteer fire fighter and I need to get in and out of my car quickly!
2008 SRT8 SuperBee #976, Options I, II, III, sunroof, rear DVD
B5976 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Ignition Switch Problem? Phlipbak Charger Problems/Assistance 7 01-02-2015 02:29 PM
Key chain weight on ignition system hendge General Charger Discussion 20 07-11-2008 12:30 AM
Ignition Key Wont Rotate Correctly GB49 Charger Problems/Assistance 1 05-31-2008 08:47 PM
Anyone Had A Problem With ignition???? ChargerSTL Charger Problems/Assistance 10 04-24-2008 10:51 AM
Key Fob wont go into ignition SkinnyVinny Charger Problems/Assistance 2 04-19-2008 06:56 PM
You may post new threads
You may post replies
