» Wheel & Tire Center
» Sponsors
» Sponsors
Go Back   Dodge Charger Forums > Dodge Charger Discussion > Interior Discussion/Modifications
Please Visit our Site Sponsors
ChargerForums.com is the largest Dodge Charger Forum on the internet. Registered Users do not see the above ads.
Thread Tools Display Modes
  #1
Old 05-28-2008, 09:09 PM
MrDolomite's Avatar
MrDolomite MrDolomite is offline
Senior Member
Plum Crazy for shift knob (late model 2007)
Edit: The shift knob on the 2007's was changed mid-year.
Edit: See http://www.chargerforums.com/forums/...d.php?t=105735 for more pics and info on how to remove the shift knob
If your car was built on or before 03/18/2007, it has the threaded shift knob and the instructions and pictures in this thread do not apply. Just turn the sucker and it should spin off.
If your car was built on or after 03/19/2007, then it has the pull-off shift knob and you should keep reading, because this applies to you.
For those of you wondering, OEM part number for the pull off shift with leather and red stitching is 04578694AA. Thanks to frogzilla8 for confirming this info.
More pics at http://www.flickr.com/photos/mrdolomite/tags/shiftknob/
__________________
MrDolomite - PLMCRZ8 (forum pics) (flickr pics) (cardomain) (fuelly)
Mods: Zoomers, Grille Lighting & Hood Scoop, Turn Signal, Front & Rear Blinker, O-rings, Pull Off Shift Knob, Underhood Dress Up, Demolded & Debadged, 6.1 HEMI badge, Thermalnator Intake Gasket, Billet Tech Underhood in new darker purple
To Do: Interior Lights, Trunk Liner, Exterior Vinyl
Last edited by MrDolomite; 11-11-2009 at 09:25 PM.. Reason: adding mid-year pull-off shift knob cutover date, adding OEM pn, add thread for removal
  #2
Old 05-28-2008, 09:10 PM
iCharge's Avatar
iCharge iCharge is offline
Senior Member
mmmm.. i like lollipops!
__________________
  #3
Old 05-28-2008, 09:34 PM
funk doctor's Avatar
funk doctor funk doctor is offline
Senior Member
Send a message via AIM to funk doctor
I haven't played pool in a while, what number is missing from that ball.
J/j It looks nice.
Quote:
Originally Posted by MrDolomite View Post
__________________
Ridng with an "89 Octane CMR Tune" by Josh@HHP
  #4
Old 05-28-2008, 10:43 PM
torred589's Avatar
torred589 torred589 is offline
Senior Member
Send a message via AIM to torred589
is that the work of BT? i really wanna get the ball, they look so clean.
__________________
Torred #589
RamAir Hood, Tinted Tails, 5% Back windows, BT Shifter, Emblems Removed, Grill/Interior Lighting, Superchip Flashpaq, Custom 589 Decals. More to come....
  #5
Old 05-28-2008, 11:20 PM
MrDolomite's Avatar
Senior Member
Quote:
J/j It looks nice.
Heh, for those who still couldn't figure it out, it started life as a 4 ball, which is purple. Dang digital cameras just can't seem to photograph that color very well.
  #6
Old 05-28-2008, 11:24 PM
MrDolomite's Avatar
Senior Member
Quote:
Nope, just home grown. Because of the goofy pull off shifter in the late model 2007s, BT doesn't have an adapter for them yet. Right now, it's just slipped onto the shaft and in extreme shift-mergencies it could pull off. I have my fabrication department, also known as my Dad, working on a more permanent attachment method.
  #7
Old 05-29-2008, 09:20 AM
ChargerChick's Avatar
ChargerChick ChargerChick is offline
Senior Member
Lifetime Supporting Member
Send a message via AIM to ChargerChick Send a message via Yahoo to ChargerChick
Well you know I love it!
__________________
  #8
Old 05-29-2008, 04:50 PM
MrDolomite's Avatar
Senior Member
The Chrome Ring - external view
The chrome ring which causes all the anxiety and issues. That little slot (which faces the front of the car when it is on the shifter shaft) does _NOT_ contain a set screw or any other item which would release the ring. My guess is that maybe it used to in the earlier models, but not on the late 2007s
  #9
Old 05-29-2008, 04:53 PM
MrDolomite's Avatar
Senior Member
The Chrome Ring - internal view
The interior of the chrome ring, The four small, rectangular indentations at 1:30, 4:30, 7:30 and 10:30 at the outermost edge of the ring are receivers for the four small, rectangular clips on the shifter knob. This is why to remove the ring, you just wedge something (something non sharp, like putty knife) between the ring and the knob and slowly push down.
Also at 1:30, 4:30, 7:30 and 10:30, further towards the bottom of the ring, and innterwards from the indentations above, are four small vertical ridges. These push against four large, white tabs on the shift knob itself and hold those tabs into the slot on the shift knob shaft. See pics that follow and it will make more sense.
Last edited by MrDolomite; 05-29-2008 at 05:06 PM.. Reason: adding info about the 4 ridges
  #10
Old 05-29-2008, 04:57 PM
MrDolomite's Avatar
Senior Member
The Shift Knob - removed
The infamous pull off shift knob. The small, c-shaped plastic tab, at 3:00, is one of four tabs which click into receivers on the chrome shift ring, see previous pic.
The four long plastic tabs, at 6:00, each have a small ridge on the inside of the plastic which click into the slot on metal shaft, see next pic. These tabs are held in place by the four plastic ridges on the interior of the chrome ring, see previous pic.
Last edited by MrDolomite; 05-29-2008 at 05:07 PM.. Reason: add info about the 4 ridges
Thread Tools
You may not post new threads
You may not post replies
Similar Threads
HHP 2007 Late Model Mopar Race #6 - MIR Raceway 8/11/07 Pictures/Videos MarylandSRT8 Mid-Atlantic Area 8 08-14-2007 05:00 AM
HHP 2007 Late Model Mopar Race #6 - MIR Raceway 8/11/07 TorRed #1179 Mid-Atlantic Area 4 08-10-2007 08:52 PM
Plum Crazy (2007) tightlines Charger Problems/Assistance 24 08-03-2007 07:44 PM
**** HHP 2007 Late Model MOPAR Points Series **** TorRed #1179 Mid-Atlantic Area 0 03-22-2007 05:22 PM
Powered by vBadvanced CMPS v3.1.0
Powered by vBulletin®. Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© AutoGuide
