Eng light came on! code P0306 #6 misfire detected! WTF!? - Dodge Charger Forums
post #1 of 10 Old 03-06-2008, 07:28 AM Thread Starter
TXboi
Senior Member
TXboi's Avatar
(Thread Starter)
Angry Eng light came on! code P0306 #6 misfire detected! WTF!?
came on wednesday and noticed my fuel mpg started to go down. hooked up my flashpaq and code 3 codes. P0306 cylinder G-misfire detected cylinder 6; U1408 no fault detected; U0184 lost comm with radio
put the car back to stock settings and bringing it in asap. i had an appt tomorrow to fix that dreaded front suspension rattle at low speeds. I'll keep u guys posted. last guy that had this code messed his eng up pretty bad. i have no internal mods that would void my warranty all i have is cai and a full exhaust system. no cam, heads or nos so i'll keep u guys posted.
Wish me luck!
2006 Charger R/T
MODS: JBA System..K&N CAI..ESP delete..93 Flashpaq.. 20" black vipers..15% tint..tinted tails..Blinker mod..Decal/Door Molding Delete..Hood decal blackout..Silverstars..Jenson 9021 touchhscreen..12" JL Sub.."Superwhite" dome lights..quarter panel stripe kit..trunk blkout..daytona grille,chin spoiler,spoiler
TXboi is offline
post #2 of 10 Old 03-06-2008, 08:21 AM
Phanta5m
Supporting Member (Lifetime)
Phanta5m's Avatar
good luck,,, let us know the outcome
Phanta5m is offline
post #3 of 10 Old 03-06-2008, 09:15 AM Thread Starter
TXboi
Senior Member
TXboi's Avatar
(Thread Starter)
just dropped the car off. its weird because as soon as i set the flashpaq back to stock settings the light went off. is that normal? i didnt clear the codes because i wanted my dealer to see the eng light. when i dropped it off i told the service rep that the light went out & he said that happens and the cpu should have the codes in the database as long as i didnt clear them. i told him i used a diagnostic cpu u know the ones u can buy at pep boys to look up codes that your car trips (didnt wanna tell the rep "oh i used my flashpaq to look up these codes"). anyways hope they fix her because the gas mileage was bad. i mean i could see my gas needle move with not even that much driving. it was like i had a 7.0L engine
TXboi is offline
post #4 of 10 Old 03-06-2008, 09:17 AM
Phanta5m
Phanta5m's Avatar
good thinking about telling them you use a diagnostic tool to read the code
Phanta5m is offline
post #5 of 10 Old 03-07-2008, 10:43 PM
Doctor No
Senior Member
Just turn key on,off on off and last on (quickly with in 3 secs)and your mileage display gives you all the codes, without a scan tool.Batt disconnnect or fuse 11 clears the codes
Doctor No is offline
post #6 of 10 Old 03-18-2008, 08:51 AM
looboy
Junior Member
looboy's Avatar
I had the same misfire codes along with a check engine light and engine stalls. I could never get it to the dealer with the check engine light on. They were no help. I stopped buying high grade fuels at low priced stations and the problem has not come back. In fact the last check engine light I had with misfire codes was cleared by high end mid grade fuel!
Bright Silver SE
R/T: 18-inch polished aluminum wheels
0% Tint
Fog Lights
looboy is offline
post #7 of 10 Old 03-18-2008, 08:54 AM
Phanta5m
Phanta5m's Avatar
Quote:
good input!
Phanta5m is offline
post #8 of 10 Old 03-18-2008, 02:12 PM
Joe123
Senior Member
Joe123's Avatar
There was a tsb on it, I had it happen to mine took it to the dealer where I found that out and they had to flash the computer and it was fine ever since.
Joe123 is offline
post #9 of 10 Old 04-15-2008, 11:55 PM
blacoste
Senior Member
blacoste's Avatar
Any idea on where there's more info on the TSB for this? Or the TSB itself?
I've had the P0302 (misfire on cylinder #2) a couple times now. Dealer said it was due to a fouled sparkplug, and that I needed to do the 30K tune up.
So I changed the plugs, oil etc. and was good for about a week, then the P0302 came back!
I read on another thread that the coil pack may be bad? Should I take it back to the dealer for them to tell me some story? Or is there something I can do myself?
GONE, BUT NEVER FORGOTTEN.
'06 InfernoRed R/T - mods: Carbon Fiber AirHAMMER
Predator, R/TJunkie NoESP, blinkers frt and rear, HD catch can, auto headlights, 'nekid HEMI's', 'Bob's exhaust', deep dark tint
blacoste is offline
post #10 of 10 Old 04-18-2008, 12:23 AM
Gilgamesh
Senior Member
Quote:
Whats wrong with that ?!?!!?
EvE
2006 charger SRT-8 Options I,II, and III
Power Ported Performance 426 HEMI stroker/ PPP stage 2 heads/ PPP custom blower cam/ Kooks longtubes/ magnaflow cat-back/ GSM 10lb supercharger/ full CMR tune(buch of other goodies)
2010 Shelby gt500- Sterling grey metallic w/ black striping- JLT CAI, C&L Tbody, 2.6 pulley, Ford Racing Super stinger exhaust, , Duel Fan heat exchanger, 180 deg t-stat
Gilgamesh is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Check engine light came on: How do I get the code? high888 Charger SRT-8 Discussion 3 01-31-2008 07:11 PM
Check Engine light code help Vanilla Gorilla Charger Problems/Assistance 10 10-25-2007 06:07 PM
Malfunction Indicator Light-wtf litlshrub Charger Problems/Assistance 8 10-13-2007 08:35 PM
check engine light code airborneSRT Charger SRT-8 Discussion 4 08-26-2007 07:41 PM
WTF dude?? Engine light... goval V6 Specific Discussion 9 07-03-2007 10:32 PM
You may post new threads
You may post replies
