I need help diagnosing a power steering issue with my 02 Dodge Stratus Coupe. Base model with a 3.0 auto.
Here is the background.
We purchased the car new with 39 miles on it. The first winter we had a problem with the power stearing fluid puking out of the reservoir past the fill cap, not alot but a good amount. It was determined the seal on the cap was bad and it was replaced. A few weeks later same thing puking out the top of the reservoir. Took it in and they claimed we must have over filled it and that is why it is leaking. Well this has been going on now for 6 years and annual trips to the dealer.
So this winter I again took it in because the pump whine was getting louder then years past. The funny thing is when you look in the reservoir you can see the fluid bubbling, which I have brought to their attention thinking it should not have pressure in there unless the pump is bad.
So two weeks ago again the issue pops up under sub zero temps...
They flushed the rack and system and stated the fluid in the lower rack was burned and we must have had an air pocket in the pump causing the puking.
All is good for two weeks.
Now this morning I have a puddle under the car and add 1 pint to top it off.
Any idea on what needs to be done? I want this fixed as the car is no longer under warranty or extended warranty.
Current miles 76,000, warranty expired 1,000 miles ago but is a well documented issue.
Any suggestions to what needs to be done?
And again this only occurrs under sub zero temps, has the pressure in the reservoir under all temps but only pukes fluid in the winter.
On a side note the car has always been harder to turn left then right and you can hear the pump working (make noise) when turning left. Front end alignment is good, all suspension pieces good end links and tie rods replaced as well as cv joints which were replaced at 60,000 miles. After the flush and refill the hard turning was resolved for two weeks until this morning.
Any thoughts would be appreciated since I am giving it one last chance to be fixed, then I will replace the rack and pump myself.
Thanks
__________________ JBA shorties complete system, K/N typhoon, hood struts, splash gaurds and now predator + 180 thermo and who knows what else....
#157 of 1400 http://s182.photobucket.com/pbwidget...a/0f9f8362.pbw
Ok this is something completely out of the blue and I know nothing about this stuff. But, maybe it was freezing at the bottom and causing it to overflow? I don't know. Just a stupid guess. I'm a dumb 15 year old.
Shouldn't be freezing even at -30, not celcius. I am guessing it's an issue with the pump and possibly the rack. So far my techs can't figure it out.
No biggie just upset with the new stain in the driveway
wow that is wild. Did they ever replace any parts? I have no idea what would cause it just curious
__________________
One of the founding fathers of "the Famm" My Rides : 2007 Detonator Yellow Charger SRT-8 Super Bee #470 of 1000
22 Elite console, Mopar catback (corsa), 376 RWHP 13.505 1/4 mile
2006 VW Jetta TDi (yes a fuel saver)
Hers: 2005 Chrysler 300 Limited 3.5L V6 (Named Benson)
Nothing replaced with the pump or rack. CV joints failed so they were replaced. End links and tie rods were worn and at the time car was aligned. It's not leaking around the hoses just right out of the reservoir from the cap cause the fluid is under so much pressure it blows past the cap and makes a big mess
