rattling noise from front end? Help please - Page 2 - Dodge Charger Forums
post #11 of 90 Old 02-17-2008, 10:28 PM
jw190m
Senior Member
same thing just started happening to me tonight. Is it safe to drive? I tried to look to see if anything was visibly wrong but its dark out so i cant see jack...
Advice??
edit: car only has 14000 miles on it so its still under warranty.
NEW: 2011 Redline Pearl SXT Rallye Plus - Mods to come
OLD: 2007 SXT - Dual Flowmasters -
- Custom Pinstriping
INBETWEEEN: 2006 Chrysler 300SRT8
jw190m is offline
post #12 of 90 Old 02-17-2008, 10:31 PM Thread Starter
TXboi
Senior Member
TXboi's Avatar
(Thread Starter)
im sure its safe to drive. but over time it can wear on our suspension system. 14000 miles? i would call up ur service dept. mine has 33000 miles so im takin mine in tomorrow ive got 3000 miles left on my warranty. i wish i had the $$$ to get the pedderized setup @ precision motorsports pretty much change out every bushing in the suspension system but it cost alot of $$$
2006 Charger R/T
MODS: JBA System..K&N CAI..ESP delete..93 Flashpaq.. 20" black vipers..15% tint..tinted tails..Blinker mod..Decal/Door Molding Delete..Hood decal blackout..Silverstars..Jenson 9021 touchhscreen..12" JL Sub.."Superwhite" dome lights..quarter panel stripe kit..trunk blkout..daytona grille,chin spoiler,spoiler
TXboi is offline
post #13 of 90 Old 02-20-2008, 02:53 PM
jdizzle3
Member
check the computer
i had this problem, under the hood in front of pass. seat the computer is mounted, and when you hit a bump it "bottoms out", if you push on it you will hear the same noise, i pulled mine out and put electrical tape on the bottom, you can even see why it happens, they used one little half inch rubber spacer,hope this helps
jdizzle3 is offline
post #14 of 90 Old 02-20-2008, 06:58 PM
jw190m
Senior Member
Took it the dealer to see what was up and they said that there was a rock stuck between the muffler and the frame. Kinda felt stupid but i didn't have any other choice but to take it in. I don't have ramps or anything to look under and I'm a big guy so crawling under the car just doesn't work for me. Needless to say I'm glad that it wasn't anything bad.
jw190m is offline
post #15 of 90 Old 02-20-2008, 11:46 PM Thread Starter
TXboi
Senior Member
TXboi's Avatar
(Thread Starter)
dizzle can u take a pic of what ur talking about.
TXboi is offline
post #16 of 90 Old 02-21-2008, 10:06 AM
R&T'sR/Tw/R/TPG
Supporting Member (Lifetime)
R&T'sR/Tw/R/TPG's Avatar
Quote:
Originally Posted by TXboi View Post
this just started last week. car has 33000 miles. i can only hear it at low speeds less than 40mph but really hear it around 10mph. its like a rattling sound thats coming from my fronts wheels. only happens when i go over bumps and cracks in the road. it sounds like something is loose like a bolt or something. i checked the wheel lug nuts and they're tight because i did them myself. doesnt happen everytime i turn the wheel only over bumps/cracks. i have stock suspension. anybody know what it could be? oh yeah my warranty is up. just my luck
I had some metallic rattles coming from the front wheels. In my case it was some loose/missing brake shield (? those metal shields on the inside area of the rotors) bolts. It was a very annoying sound... I discovered it by getting under the car and playing with parts around the wheel area. I hope your fix is an easy one.
R&T
2006 Silver R/T with the R/T Perf Grp (not stock anymore....) 1/4mi - not yet
my grandfather had a saying: Wenn Dummheit weh tšte, dann wurde die Menschheit schreien..
which loosely translates to:
"If stupidity were painful, mankind would be screaming"
R&T'sR/Tw/R/TPG is offline
post #17 of 90 Old 02-21-2008, 10:52 AM
Boggus
Senior Member
Mine was sway bar end links..... only happened at low speeds and over bumps.
Daytona TB #3120
Boggus is offline
post #18 of 90 Old 02-21-2008, 06:52 PM
spongebobhemipants
Senior Member
spongebobhemipants's Avatar
happening to me too.. going over small bumps at 10mph ( manhole covers, drains) there is a quicj clunking from right front. When i go over the same bumps with left tires, no noise.
I checjed the computer./ fuse box under the hood mentioned in this thread and it was fine. Going in to dealer Saturday for oil change/tire rotation , so will report that as well. 18,000 miles..
spongebobhemipants is offline
post #19 of 90 Old 02-21-2008, 08:36 PM
daghostmon
Senior Member
I've also got the same problem. The front clunks when going over bumps, pot holes, etc. I've had it in the dealerships 3 times and of coarse the dealer can't here it. I'll tell you what though its a bunch of annoying problems like this and lack of dealer support that will keep me from buying another DCX car. I also have a honing noise coming from the front left tire when braking at a rolling stop I believe is related.
07 Black RT, HEMI 5.7L
No ESP mod, rear spoiler, AFE stage 2 intake, superchips powerpaq.
daghostmon is offline
post #20 of 90 Old 02-27-2008, 09:47 PM
MDRT
Member
I noticed a rattling sound coming from the front passenger side. Sounds similar to what a lot of people are referring to. Driving relatively slow hitting bumps such as manhole covers etc.
It took me a long time to figure out what it was. The dash started to rattle. I hove over 36K so I haven't taken it to a dealer. I haven't had a chance to look at it to see if I can figure out what the cause is. If you wedge something between the dash and the windshield the rattling sound will go away.
06 Charger R/T
Date of MFR: 8-05
Inferno Red Crystal Pearl Coat
Electronics Convenience Group, Convenience Group II, Sound Group II, Sirius Satellite Radio.
Auto Headlight Mod, Trunk Spacer Mod,
No other mods,,, yet
MDRT is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
thumping/popping noise in front end info@PeddersUSA.com Wheels/Tires/Brakes/Suspension 5 01-02-2015 03:32 PM
Need help with front end noise please.... Bones1274 Charger Problems/Assistance 3 05-21-2007 11:08 PM
Clunk noise in front end gomango2103 General Charger Discussion 7 04-20-2007 07:53 PM
rubbing noise from front end noggy_t_doggy Charger Problems/Assistance 4 01-16-2007 01:36 PM
front end noise. rawj7 Performance Discussion/Modifications 3 08-03-2006 11:00 AM
You may post new threads
You may post replies
