Long Crank to Start When Warm - Dodge Charger Forums
Charger SRT-8 Discussion This area is for discussion involving the SRT-8 version of the Dodge Charger.
post #1 of 21 Old 12-21-2007, 03:35 PM Thread Starter
swexlin
Senior Member
(Thread Starter)
Ever happened you any of you? Happened to me for the first time tonight. Had driven 15 miles home from work, stopped at the gas station 5 minutes to fill up. Turned the key to start and.....crank.....crank.....about 4-5 seconds. Haven't heard that since the carburator days. She normally always fires within 1-2 seconds.
Very weird. I'm think it has something to do with the crank sensor. Anybody experience something similar?
2013 Dodge Dart SXT 1.4L Turbo 6-speed Blue Streak Pearl
2007 Dodge Charger SRT8 Superbee Detonator Yellow Option Group I; 722/1000
2003 Dodge Viper SRT10 Black
swexlin is offline
post #2 of 21 Old 12-21-2007, 03:56 PM
mywhitecharger
Senior Member
mywhitecharger's Avatar
I had that going on until I got the Sunroof TSB fixed and the dealer charged me up.
Apparently the sunroof still draws current when the car is off. I didn't affect me until the this year when it got cold.
mywhitecharger is offline
post #3 of 21 Old 12-21-2007, 04:08 PM Thread Starter
swexlin
Senior Member
(Thread Starter)
I don't think that's it - battery has plenty of juice, according to EVIC. I'm thinking some kind of vapor lock, or the position of the throttle sensor when I stopped the car.
I've used this car to run numerous errands, and had many "hot starts" after it's been sitting only a few minutes, which is why it surprised me.
swexlin is offline
post #4 of 21 Old 12-21-2007, 05:28 PM Thread Starter
swexlin
Senior Member
(Thread Starter)
Hemi31 over on ****** suggested I may have filled the tank too much (I always squeeze in a bit more after the click), and this may have caused it.
I never heard of this before.
swexlin is offline
post #5 of 21 Old 01-29-2010, 08:32 AM Thread Starter
swexlin
Senior Member
(Thread Starter)
Resurrecting this, as I had an interesting issue today. Started the car this morning to go to work, it has been sitting for 6 days, and temp was 18*. She fired right up. Got to work, and it sat 1.5 hours, went out to run an errand, and she cranked at least 5 seconds. Almost thought she wasn't going to start. Drove about 2 miles, had to stop and drop off some mail, car was shutoff maybe 1-2 minutes, and then she fired right up again.
Get to my next destination, where it sat about 1 hour. Temp is now only about 23*. Came out to start her, and again, cranked 3-4 seconds this time. What is going on? She starts instantly after a week of sitting, but on after sitting 1-2 hours, she is taking a while to light - engine turns over just fine, and battery in EVIC is averaging 14.1 volts, as it always has since new. I've had it 3 years in February, 10,000 miles on her. Car is now going to sit about 6 hours, so I guess I'll see what happens when I go to start her up this afternoon.
Just something with the cold?
swexlin is offline
post #6 of 21 Old 01-29-2010, 08:39 AM
370 HEMI
Supporting Vendor
370 HEMI's Avatar
Have you ever done an oil analysis? You may have leaking or seeping injectors. When they seep or leak, and then you try to start it up you get a slight flooded condition causing more cranking etc.
I have seen several LX cars with this issue. A simple fuel rail leak down proceedure will also show the problem it that is the cause.
Just a thought.
Regards,
Brian
BND Automotive LLC
440-821-9040
More Power, More Torque, Better MPGs - It's "Rocket Fuel For Your Car"
Custom Designed & Custom Blended "ALWAYS beats off the shelf brands"
Better cooling, better protection without all "The Gunk"
370 HEMI is offline
The Following User Says Thank You to 370 HEMI For This Useful Post:
ronsamx (12-16-2014)
post #7 of 21 Old 01-29-2010, 08:52 AM Thread Starter
swexlin
Senior Member
(Thread Starter)
I thought of a fuel rail leakdown myself. Car only has 10,000 miles, and never an issues. Why would the car start instantly after sitting for a week though, if this were the case?
swexlin is offline
post #8 of 21 Old 01-29-2010, 09:06 AM
370 HEMI
Supporting Vendor
370 HEMI's Avatar
That would be because the gasoline had time to vaporize and then go out of the chamber....open valves, pcv etc. It is when it is warm and spritzing while sitting there under pressure and still wet that it produces the flooded condition.
Brian
BND
370 HEMI is offline
post #9 of 21 Old 01-29-2010, 09:07 AM
370 HEMI
Supporting Vendor
370 HEMI's Avatar
Quote:
Call me, we can discuss.
Brian
BND
440-821-9040
370 HEMI is offline
post #10 of 21 Old 01-29-2010, 09:12 AM Thread Starter
swexlin
Senior Member
(Thread Starter)
Interesting. I'm sure if I took it to my dealer, they would be "unable to duplicate", or just tell me that those crank times were within the realm of normalcy.
swexlin is offline
  Dodge Charger Forums > Dodge Charger SRT-8 > Charger SRT-8 Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
To warm up or not to warm up??? sleemie General Charger Discussion 20 12-22-2007 10:30 AM
how long should one warm up there hemi in the morning inky General Charger Discussion 29 12-02-2007 03:12 AM
Looking for remote start installer in NYC/Long Island? Nyczbubba Mid-Atlantic Area 2 10-27-2007 11:19 PM
How long do you let your charger warm up before driving? Andre General Charger Discussion 22 01-18-2007 07:57 PM
Still Warm Racer X Performance Discussion/Modifications 2 08-20-2005 09:47 AM
You may post new threads
You may post replies
