Ignition Switch Problem? - Dodge Charger Forums
post #1 of 8 Old 12-06-2007, 09:31 PM Thread Starter
Phlipbak
Senior Member
(Thread Starter)
I have an '06 Dodge Charger (SXT), and when I go to put my key in the ignition, if I turn it all the way to crank (on) as SOON as I put it in, nothing happens at all (like my electronics don't even cut on, nor does it start to crank), I have to turn the key back to off and do it again and it works (starts to crank), am I just doing it so fast it is slipping out of the key grip in the ignition or do I have a faulty ignition/key grip or what? It does this quite a bit but if I put it in the ignition then wait a millisecond and not turn the key quite so fast it cranks fine, am i just doing it too fast? It does this on occasion, quite a few times, but mostly only when I do it fast, doesn't affect anything else really, just bothersome. Any ideas? My problem or the cars? Again, everything else works fine and it doesn't affect anything.
Thanks!
Trevor
Phlipbak is offline
post #2 of 8 Old 12-10-2007, 02:00 PM Thread Starter
Phlipbak
Senior Member
(Thread Starter)
bump, any suggestions?
Phlipbak is offline
post #3 of 8 Old 12-10-2007, 02:50 PM
optimus124
Senior Member
optimus124's Avatar
Send a message via AIM to optimus124 Send a message via Yahoo to optimus124
Sometimes when I'm in Knieval mode, I have a similar issue. The car starts to crank, but it does not turn over. It only happens when I am a little fast. You may just need to cool it down on the startup
optimus124 is offline
post #4 of 8 Old 12-10-2007, 10:17 PM
Crow
Senior Member
The PCM runs a few checks before it will allow you to start. If you try to start it to fast, it will just sit there and do nothing.
The V-6 seems to be a bit more effected by it. I believe there is TSB out for the condition.
Read the stated symptoms/conditions in the TSB and see it they match your problem. Remember, a code does not have to be present.
http://www.wkjeeps.com/misc/LX/TSB/TSB_1803106.pdf
Crow is offline
post #5 of 8 Old 12-10-2007, 10:26 PM
wickedchargerrt
Banned User
wickedchargerrt's Avatar
Like crow said it takes a second for the skeem system to read the key before it will allow you to start. Otherwise it doesnt see the chip/resistance in the key and it thinks your stealing your car. welcome to microsoft sxt
wickedchargerrt is offline
post #6 of 8 Old 12-12-2007, 09:19 PM Thread Starter
Phlipbak
Senior Member
(Thread Starter)
Ha ha, microsoft sxt, i love it. Anyways, thanks fellas, and I know chargers have a problem with tranny o rings, how do i know if mine is having the problem? just trying to stay on top of the game lol
Phlipbak is offline
post #7 of 8 Old 12-13-2007, 09:47 AM
Crow
Senior Member
Quote:
When you see a red puddle under your car. Or, next time you do an oil change look at the underside of the tranny, if its dry, your OK. Just keep an eye on it at every oil change.
Crow is offline
post #8 of 8 Old 01-02-2015, 03:29 PM
Yshwedekolo
Junior Member
What I*read*I really liked it.*Thank you for*your information!
Yshwedekolo is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Cutout switch using the Pedal Adjustment Switch potsyboy Charger SRT-8 Discussion 10 11-13-2007 06:40 PM
Ignition switch swap? toxico Charger Problems/Assistance 2 09-27-2007 07:26 AM
Ignition Mod?? Big Harm General Charger Discussion 5 09-18-2007 07:21 PM
FS: Headlight Switch Assembly with Fog Lamp Switch 440Six-Pack Parts For Sale/Wanted 1 05-03-2007 11:12 AM
Headlight Switch Problem oldF1fan Interior Discussion/Modifications 3 10-29-2006 03:36 PM
You may post new threads
You may post replies
