check engine light is on - Dodge Charger Forums
Charger SRT-8 Discussion This area is for discussion involving the SRT-8 version of the Dodge Charger.
post #1 of 19 Old 11-09-2007, 11:51 AM Thread Starter
Beaky73
Senior Member
(Thread Starter)
Hello to all, I took my 07 srt8 to the dealership today to fix have my tire fixed. i had a screw in it, so i figured i will have the oil changed. When i went to pick up my car, the service guy asked how long my check engine has been on. i told him never. so now my check engine light is on. do you guys think it has soemthing to do with my programmer. when i get home i will look for codes. any ideas would help. thanks to all....
2007 Dodge Charger SRT8 (belonged to Chase Utley)
Airraid CAI, Diablo, 180* t-stat, Pioneer AVIC-Z2 and Zoomers exhaust, RE 10" sub and speakers, Powerbass 5 Channel Amp, Toyo Proxes 4 ZR tires, more to come
Beaky73 is offline
post #2 of 19 Old 11-09-2007, 12:00 PM
elcobra44
Senior Member
elcobra44's Avatar
Did you do the key trick to get the engine code? Flip the key from on to off a few times without actually starting the car to get the error code displayed where your mileage is.
Didn't the dealer check the code for you?
elcobra44 is offline
post #3 of 19 Old 11-09-2007, 12:10 PM Thread Starter
Beaky73
Senior Member
(Thread Starter)
i will go out and do the key trick.... no the dealer didnot see ehat the code is... they just said the light was on.... once i get the code where can i find out what it is
Beaky73 is offline
post #4 of 19 Old 11-09-2007, 12:12 PM
Mecha
Senior Member
Mecha's Avatar
Quote:
you mean to say you were at the dealer THE DEALER and a code showed and they didnt tell you what was wrong?
I would go back to that dealer and make them explain what the deal was.
Mecha is offline
post #5 of 19 Old 11-09-2007, 12:14 PM Thread Starter
Beaky73
Senior Member
(Thread Starter)
i tried the key an nothing happened.... no code...... i will wait till i get home and see what the diablo says
Beaky73 is offline
post #6 of 19 Old 11-09-2007, 12:20 PM Thread Starter
Beaky73
Senior Member
(Thread Starter)
they did not hook it up to find out what was wrong. they thought i new about it. i hope they did not do something to screw up my programming. all thay did was fix a flat and change the oil. what could thy have done to have the check engine light come on.
Beaky73 is offline
post #7 of 19 Old 11-09-2007, 12:26 PM
charger22DUB
Senior Member
They should have done it right then and there. I would be calling the service manager and complain its redicoulus that the dealer would let the car go with the check engine light on unless you wanted to take your car home and didn't want them to look at it cause you still had you diablo program on it?....
SRT8 Options l ll & lll, Sunroof, and Side Airbags
NO MORE HEAVY 22's, only stock 20's
Purchased on 10/12/07
charger22DUB is offline
post #8 of 19 Old 11-09-2007, 12:31 PM Thread Starter
Beaky73
Senior Member
(Thread Starter)
thay called me and said it was done so i said i will be there on my lunch break and as i was paying for the service is when they told me about the light. so i ok. so i will go home and see what it is and take it from there. i am hoping it is something stupid. i will not go back to that dealership.
Beaky73 is offline
post #9 of 19 Old 11-09-2007, 12:35 PM
charger22DUB
Senior Member
Hmmm well if you didn't do anything to your car and you loaded the original settings why wouldn't you take it back?
post #10 of 19 Old 11-09-2007, 12:38 PM
Mecha
Senior Member
Mecha's Avatar
it takes all of five min to hook up and read the codes from the car.... they could have done that. you just had a lazy arse tech working on your car.
hope they did the oil change right.
hmm not sure about our cars but it used to be stanard practice where ever you took your car in for an lube/oil change they check all the fluids. to check the trans fluid on the charger you need a starscan. that reads codes too...
make sure you did the key trick right to get the codes.
Mecha is offline
  Dodge Charger Forums > Dodge Charger SRT-8 > Charger SRT-8 Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Check Engine Light - How to Check Codes PikeBoy98 V6 Specific Discussion 27 01-11-2016 09:38 AM
check engine light came on slick V6 Specific Discussion 6 07-14-2008 05:23 PM
Check Engine Light PythonSRT8 Charger SRT-8 Discussion 15 04-30-2007 07:51 AM
check engine light STMhellion505 Performance Discussion/Modifications 1 11-20-2006 07:09 AM
Check Engine Light On torkin Charger SRT-8 Discussion 2 09-27-2006 07:05 PM
You may post new threads
You may post replies
