Transmission wont shift?! - Dodge Charger Forums
post #1 of 20 Old 12-20-2005, 08:49 AM Thread Starter
charger71
Member
(Thread Starter)
Ok.. weirdest thing happened to me today.
I get off the highway on my commute to work.. Get stuck in some stop and go traffic, then turn onto a side road. Step on the gas and the car kinda just makes noise and doesnt really go.. I floor it, and it didnt downshift.. uh oh I think.. so i slap the shifter to the left.. nada.. left right left right.. nada.
Neutral, ok that works. Back to D, still wont shift.. I'm getting scared now. Get to a light, put it in park, turn off the car, restart, put it in D. ok, that felt good.. shift left, ok, went into first.. good.. back to D, move in traffic, everythings working. Floor it, it downshifts fine, upshift is good, no problems.
Thats the first time that ever happened... Should I be worried? Is it time to remove the jet chip and take her in?
Its an 06 R/T, 2800 miles on her, jet chip and K&N cai
charger71 is offline
post #2 of 20 Old 12-20-2005, 08:57 AM
HIGH_HEMI
Senior Member
HIGH_HEMI's Avatar
Talking Re: Transmission wont shift?!
I would definitely take her in for a check up. Let them know exactly what happened.....happened once and ya don't want it happening again leaving you stranded. Plus, nothing worse than watching your brand new car sit on the side of the road dead....and all the ricers driving by thinking...uhuh, POS.
5.7L HEMI REGISTRY # 00375 HIGH_HEMI
2006 Dodge Charger R/T
Mods: forzaflow mufflers-no resonators
HIGH_HEMI is offline
post #3 of 20 Old 12-20-2005, 09:10 AM
Crazy_luck
Senior Member
Crazy_luck's Avatar
Send a message via AIM to Crazy_luck Send a message via Yahoo to Crazy_luck
I had a similar thing happen about a month and a half ago. The CEL came on when I went to pass a slower car and I lost power. The engine was still running, but there was no throttle/trans response. The code I got was 'unknown/improper gear reatio' which IIRC, has something to do with the rear ABS sensor. I never had to have anything fixed, the problem went away on its own..... (at the time the car was completely stock, it was going in that night to get the exhuast done, I was gonna have that shop look into it, but it fixed itself on the way there)
Crazy_luck is offline
post #4 of 20 Old 12-21-2005, 08:22 AM Thread Starter
charger71
Member
(Thread Starter)
well.. it ran fine all day yesterday, drive home was fine.
this morning on the way to work again I had the problem. Went to play with an evo and noticed the car wouldnt downshift..
then the CEL came on and I lost power.. pulled over. Did the key dance to check the code.. - - - - - few seconds later - done
wtf? no code? so I drove a little, still had some power issue, couldnt accel. Restarted the car again.. drove slowly.. gave it more gas, hmm seems to run fine.
Next light, turned her off, checked for a code, still -----.. Restarted, and CEL is gone and car runs perfectly again..
Any ideas? If my jet chip was the cause, shouldnt this be continuous? IE, jet causing me to throw a code, it shouldnt just go away should it?
post #5 of 20 Old 12-21-2005, 08:41 AM
Ron Mexico
Senior Member
Ron Mexico's Avatar
Sounds like she's getting sicker... Take her into the Doctor, Please!!
'06 R/T CHARGER Midnight Blue
MODS- Auto lights, mirror tint
CAI, hood props, MAgnaflow suitcase replace
and resonator delete.
'93 Ford Ranger big 6 (little workhorse)
Ron Mexico is offline
post #6 of 20 Old 12-21-2005, 09:29 AM
DanX
Junior Member
I had a similiar issue. Took her in and the dealer found that the e-brake cable was rubbing on the yellow wire to the tranny harnes. Apperently the zip tie (or whatever holds the harnes) had come off.
Hope your issues is as minor as mine was.
DanX - GoManGo Daytona #964
- Auto headlights
- Silverstars
DanX is offline
post #7 of 20 Old 12-27-2005, 07:01 PM
jazztrumpet216
Junior Member
Hello all-
I was browsing through the forums here and came upon this problem. I am a Chrysler minivan driver and having the 4 speed auto, I'm aquainted enough with various transmission issues. What happened to you sounds to me like your transmission went into "limp home" mode. What this means is that your tranny went to 2nd gear and stayed there, to avoid shifting. This usually happens because the TCM has sensed something wrong with either the transmission or another related part of the drivetrain, kind of like a failsafe. It can be anything from a serious transmission issue to something like DanX's wire harness problems (I would think and hope that it would be something like this). When it goes into limp home mode, you may or may not be able to regain all of your gears by restarting your car, and you will *usually* have neutral, park, and reverse.
I would say you should see your dealer and ask them to check the TCM for any codes. You probably won't find anything by doing the key dance in this instance.
jazztrumpet216 is offline
post #8 of 20 Old 12-27-2005, 08:34 PM Thread Starter
charger71
Member
(Thread Starter)
quick update.. dealer said there were 2 codes, tranny related, something about the transmission solenoid..
That was at 5pm the day I took it in, said theyd work on it the next day.
Next day, nada. Day after, they call me at 1 and say its ready.
I go in and they tell me nothings wrong, they didnt get any codes, test drove it, etc.
Damn.. I'm wondering if its the jet chip? this happend 3 days after jet chip install, and hasnt happened again since I took it to the dealer. (removed the chip prior to taking it to the dealer)
Wonder if the increased shift pressure from the chip was anomalous and caused the limp mode?
Only one way to find out.. gotta put the chip back in and see if it happens again.
post #9 of 20 Old 12-27-2005, 10:53 PM
jpagan
Senior Member
jpagan's Avatar
I had the same problem and it was the transmission. the dealer ended up ordering a new tranny and installing it. Now no problems at all and runs like new.
JC
Bright Silver R/T 5.7L HEMI
Current MODS:
HoneyComb Grill with RT insert/MOPAR Front Lip spoiler/Rear Air Diffuser/Sylvania Bright white bulbs/Magnaflows exhaust/ Custom tips/ Daytona Style wing.
jpagan is offline
post #10 of 20 Old 12-28-2005, 01:40 PM
R/TommyB
Senior Member
R/TommyB's Avatar
Send a message via AIM to R/TommyB Send a message via Yahoo to R/TommyB
Quote:
Interesting observation. This is actually covered in the charger manual, so it is indeed a feature of our transmission. IIRC, there is also a blue or pink switch buried underneath the storage tray adjacent to the shifter that allows you to deactivate limp mode.
'06 'Mango
Mopar CAI + Bassani, Auto headlight module; Rockblocker tails, and fogs; Ultimate Pedals, 22elite center console cover, Mango calipers, EBC 3GD rotors with Red Stuff pads, Razor's Edge strut tower brace, Anzo Halos, BT Underhood Kit, Beehives, & Coil Covers, and Predator.
'04 Crossfire LTD
R/TommyB is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
WHAT MODs WONT VOID MY WARRANTY 3.5L ChargeIT Exterior Discussion/Modifications 11 05-26-2006 10:36 AM
HELP!!!! Tranny wont SHIFT AFTER STEREO UPGRADE BlueonBlack Performance Discussion/Modifications 17 02-24-2006 03:23 PM
Funny Cadillac STS wont get over MrScary General Charger Discussion 1 01-18-2006 06:01 PM
Cars Security System-Wont Start 2006MangoCharger-Oregon General Charger Discussion 1 12-07-2005 06:26 PM
transmission shift delay? angrrmgt General Charger Discussion 11 11-14-2005 03:25 PM
You may post new threads
You may post replies
