Replaced my plugs today- very easy! - Dodge Charger Forums
General Charger Discussion General Discussion about the Dodge Charger.
post #1 of 138 Old 08-12-2007, 09:13 PM Thread Starter
DA X 6
Senior Member
DA X 6's Avatar
(Thread Starter)
Well, today I pulled the plugs. I had 29,549 miles on the General, and it was time. I HIGHLY recommend this as a DIY project based on what others report dealers charging for this maintenance. I've heard figures of $250.00 to well over $400.00. I paid ~$25.00 for 16 OEM Champion RE14MCC4 plugs from rockauto.com.
Here are a few post mortem thoughts:
1) Unlike other cars I've worked on, the rearward plugs were easier to pull. The plugs for #1 cylinder were blocked by the oil dipstick tube, and it was necessary to pull the airbox to access the plugs for #2 (those of you with CAI's can probably avoid that step).
2) A rudimentary socket set is all that is required. You need a 5/8" spark plug socket, a U-joint, and a 4" extension, in that order.
I would have posted pics, but wife & kids were away for the weekend and took the camera with them...
The whole process took me about 2 1/2 hours, mostly because I kept having to go back into the house for more beer...
The General Sherman / 2006 Charger R/T, Bright Silver
Poor Man's mods: Auto Headlights/Hood Struts/Visor Stickers/Bumper Scratch fix (O-rings)/Lock Pin O-rings/Blinker Mod/RD Hardwire/Cabin Air Filter/Storage Compartment/Blue Calipers/Honeycomb Grill Insert w/R/T Badge/Belly Pan Mod/GTS rain guards/aFe drop-in air filter/Gorilla Lug Nuts/Rear Blinker Mod/Backup Camera/Fumoto valve/PAC Audio media input/Challenger rims
DA X 6 is offline
post #2 of 138 Old 08-12-2007, 09:16 PM
Slow4Dr
Senior Member
Slow4Dr's Avatar
Just a general question, how often should you change out plugs?
Slow4DR, she's gone but not forgotten
Slow4Dr is offline
post #3 of 138 Old 08-12-2007, 09:19 PM Thread Starter
DA X 6
Senior Member
DA X 6's Avatar
(Thread Starter)
Quote:
Every 30,000 miles for the 5.7s.
DA X 6 is offline
post #4 of 138 Old 08-12-2007, 09:20 PM
wickedchargerrt
Banned User
wickedchargerrt's Avatar
every 30k. . .
wickedchargerrt is offline
post #5 of 138 Old 08-12-2007, 09:20 PM
TBYDaytona40
Senior Member
TBYDaytona40's Avatar
Location: Lookin for a second, third, and fourth wife.....
Dodge recommends 30K interval between changes. That is probably because they are a copper plug, and over time the copper center electrode wears, causing an increase in spark plug gap, which eventually will cause misfirings. A full platinum plug is less prone to gap wear (though it will still happen but over a longer period of time). That is why Ford and GM use platinum plugs, and say 100K miles before the first tune up.
Top Banana #40 of 4,000. Supporting Vendors who have helped with my Daytona. I support them. They are good, trustworthy vendors: BilletTechnology! RiderGraphix! DMH Cutouts, MPSC, DankoReproductions, RockBlockers, ReflectiveConcepts My pics are here:
TBYDaytona40 is offline
post #6 of 138 Old 08-12-2007, 09:25 PM Thread Starter
DA X 6
Senior Member
DA X 6's Avatar
(Thread Starter)
Oh, I also meant to say that if you have jack stands, or ramps, lift the front end and remove the belly pan, because you're GONNA drop stuff. I dropped the socket & plug TWICE, and the coil pack bolts THREE times!
DA X 6 is offline
post #7 of 138 Old 08-12-2007, 09:33 PM
ga charger
Senior Member
3.5 uses platinum every 100k.
ga charger is offline
post #8 of 138 Old 08-12-2007, 09:38 PM
Charger06RT
Senior Member
Charger06RT's Avatar
Quote:
I second that. I did my plugs at 30K and in the middle of replacing them, I dropped my socket. I didn't have the belly pan removed and I couldn't drive the car on the ramps to remove it. I had to pull the splash shield just under the front bumper and stick my arm in the pull out the socket.
Charger06RT is offline
post #9 of 138 Old 08-12-2007, 09:42 PM
carchitect
Senior Member
carchitect's Avatar
I'm actually looking forward to changing the plugs on my 5.7 after having to do the plugs on my dad's 3.9 in his Ram 1500 Van today.
It was the first time I've worked on a vehicle from the inside, outside, and underneath just to try to get one stinking plug out.
carchitect is offline
post #10 of 138 Old 08-12-2007, 09:46 PM Thread Starter
DA X 6
Senior Member
DA X 6's Avatar
(Thread Starter)
Yeah, your R/T will be much easier- there's no need to be a contortionist at all. I did use a breaker bar on #7, but all else was very easy.
DA X 6 is offline
  Dodge Charger Forums > Dodge Charger Discussion > General Charger Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Spark Plugs... arfur General Charger Discussion 14 03-28-2008 04:57 PM
16 Spark Plugs..!!! BullsEye Performance Discussion/Modifications 25 06-27-2007 12:53 AM
spark plugs marshallpollock2 Performance Discussion/Modifications 4 05-29-2007 05:38 PM
What spark plugs to get? Alley Charger SRT-8 Discussion 0 05-27-2007 10:26 PM
TCM Replaced Today 2KWK4U Charger SRT-8 Discussion 75 03-02-2006 07:09 PM
You may post new threads
You may post replies
