What type of fuel should I use in my 3.5 - Dodge Charger Forums
V6 Specific Discussion This area is for discussion about V6 powered Dodge Chargers.
post #1 of 31 Old 07-03-2007, 12:29 PM Thread Starter
ChargerFan2006
Member
ChargerFan2006's Avatar
(Thread Starter)
for my v6 3.5L charger?
2008 Blue Superbee #284 / OPT GRP I II III / SunRoof / MORE TO COME...
ChargerFan2006 is offline
post #2 of 31 Old 07-03-2007, 12:31 PM
SupremeG
Senior Member
SupremeG's Avatar
I think 89 is recommened.
SupremeG is offline
post #3 of 31 Old 07-03-2007, 12:34 PM
TopBanana107
Senior Member
TopBanana107's Avatar
Check the owner's manual. Says it there. What have you been using up to this point?
Sig by AreTee|Grafix
2006 TopBanana Daytona 107/250 born in December 2005, purchased August 2006. Back in Chrysler's hands October 6th 2009
Nanner may be gone but is not forgotten...I have waaaaaaaay too many pictures to forget Nanner!!!
TopBanana107 is offline
post #4 of 31 Old 07-03-2007, 12:35 PM Thread Starter
ChargerFan2006
Member
(Thread Starter)
Quote:
Regular
post #5 of 31 Old 07-03-2007, 12:40 PM
birddog
Senior Member
birddog's Avatar
89 is what you car should run best with.
If you use 87, you're computer may adjust the timing, so you may not hear the knock (which normally indicates that you need higher octane) but, when it does, it reduces your mileage and will not save any money.
If you really want to go with 87 to save money -- run several tanks of 87 and track your mileage. Then run several tanks of 89 (similar driving conditions) and track your mileage. If your mileage is as good or better with 87, then, by all means: use it.
'06 Charger RT (original owner)
birddog is offline
post #6 of 31 Old 07-03-2007, 12:42 PM
TopBanana107
Senior Member
Regular's ok for your car...you're not thinking of using Premium are you...would just be a waste of money. Did you check your owner's manual? Before the SC 91 tune on my car, 89 was recommended, while 87 was acceptable...and I have the 5.7 Hemi.
post #7 of 31 Old 07-03-2007, 12:47 PM
TNCHARGER
Senior Member
There is a misconception about premium fuel that it makes more power...prem actually has less BTUs per gallon than regular. The higher octane is only to keep the fuel from detonating before it is supposed to..
Modifications like increased compression and spark advance require the higher octane or spark knock would occur...the advantage here is compression and timing result in more power than is lost from the lower BTUs..
If your car is not designed to use higher octane you will actually lose power...
TNCHARGER is offline
post #8 of 31 Old 07-03-2007, 01:40 PM
cjsCharger
Senior Member
cjsCharger's Avatar
I always use 89, I've tried 87 for a while, but I had less power and my mileage was worse so I went back to using 89.
Backup Ride - 1995 Deep Garnet GMC Yukon GT 2Door 5.7 L 350 V8 Mods -Full Audio System -7" In Dash DVD Player -20% Tint -Tow package
cjsCharger is offline
post #9 of 31 Old 07-03-2007, 02:44 PM
curlie39
Senior Member
curlie39's Avatar
Send a message via Yahoo to curlie39
Quote:
X2
NEMC senior member Ride Growler
curlie39 is offline
post #10 of 31 Old 07-03-2007, 04:06 PM
ga charger
Senior Member
Quote:
Originally Posted by curlie39 View Post
X2
x5 damn I hate that.
ga charger is offline
  Dodge Charger Forums > Dodge Charger Discussion > V6 Specific Discussion
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Fuel pump and fuel rails. ultrablue Performance Discussion/Modifications 8 08-23-2008 07:42 AM
need help, fuel injector spraying fuel sinistersix Performance Discussion/Modifications 2 08-11-2008 10:04 AM
Instant fuel economy vs. Average fuel economy nheitz General Charger Discussion 13 06-02-2008 08:30 PM
Ethanol Fuel mix VS Fuel Injection Health cfbenoit General Charger Discussion 2 10-16-2007 09:18 PM
FS : New Aeromotive Fuel Pump And Fuel Filter D Town Charger Parts For Sale/Wanted 0 08-02-2006 08:56 AM
You may post new threads
You may post replies
