What is the IAT sensor & what does it do? - Dodge Charger Forums
V6 Specific Discussion This area is for discussion about V6 powered Dodge Chargers.
post #1 of 13 Old 06-25-2007, 06:09 PM Thread Starter
ssballow
Senior Member
ssballow's Avatar
(Thread Starter)
I know where it is on my intake, but someone was saying that they made a run with it out. what is it for if you can drive the car with it out?
3.5L SE :
17"SGT aluminum alloy wheels, spectre cai, esp delete, custom dual borla catback exhaust, tint (35% up front and as dark as they get in back!)
ssballow is offline
post #2 of 13 Old 06-25-2007, 06:16 PM
blairian
Super Moderator
blairian's Avatar
You can run without it, and a few have said that they saw gains (the highest I saw was 8 RWHP) but as far as exactly what it does you got me...
I BELIEVE it keeps track of the either the amount of air entering or the temperature and then accordingly changes the amount of fuel being put into the engine
2007 SuperBee #849
SRT Option Groups I, II, and III
Quote:
Originally Posted by SupremeG View Post
I've had a chance to ride in Blairian's SRT and that thing is a monster. I couldn't stop smiling the entire time I was in the SRT.
370 HP, 375 LB/FT, Air Temp 80*
blairian is offline
post #3 of 13 Old 06-25-2007, 06:21 PM Thread Starter
ssballow
Senior Member
ssballow's Avatar
(Thread Starter)
So, I can cut it out altogether?
ssballow is offline
post #4 of 13 Old 06-25-2007, 06:24 PM
blairian
Super Moderator
blairian's Avatar
Quote:
I wouldn't recommend cutting it out altogether...
I think IAT stands for Intake Air Temperature sensor
blairian is offline
post #5 of 13 Old 06-26-2007, 12:07 AM
firemnfrank
Senior Member
firemnfrank's Avatar
The IAT sensor is there to detect the temp of the air entering the engine from the intake. The signal sent from the sensor tells the computer what timing and amount of fuel the engine needs according to the air temp itself.
It is NOT the only sensor that controls the fuel and timing, there are many others sensors, these also include the O2 sensors, MAP (manifold air pressure) sensor and many other sensors and parameters to ensure the engine works properly.
One trick is to place a resistor in line with the sensor to trick the engine to think it is colder outside, then it will change the fuel and timing, not by much and therefore the changes are not dramatic and our computers adapt them selves and readjust.
If you disconnect the sensor or add to much resistance you will end up with a code and check engine light, I have played with this and other sensors and the car ran best by leaving it as it came.
Hope this helps,
firemnfrank is offline
post #6 of 13 Old 06-26-2007, 12:12 AM
blairian
Super Moderator
blairian's Avatar
Hope this helps,
Thanks Firemnfrank!
blairian is offline
post #7 of 13 Old 06-26-2007, 03:54 AM
wishing for hemi
Senior Member
wishing for hemi's Avatar
even with the code will taking it out give you a noticable diff. in pwr or at least throttle response? throttle responce is my biggest complaint.
wishing for hemi is offline
post #8 of 13 Old 06-26-2007, 06:53 AM
DaILLestWun
Senior Member
DaILLestWun's Avatar
I took it off when I dynoe'd and my HP jumped up 8hp. At the track I shaved about .2 off my time but I also deactivated the ESP via the stock button on the dash.
I wouldn't drive around with it out but a good thing to do would be to extend it as close to the filter as possible so that it gets the coolest air possible.
World's first tuned V6 LX!!
DaILLestWun is offline
post #9 of 13 Old 06-26-2007, 08:51 AM
GLHS837
Super Moderator
GLHS837's Avatar
Quote:
You should know that the car responds to how fast you press the throttle, not just how far. Faster press should get you a quicker response. Jab the throttle, and she'll lunge, slowly press down, she'll gently ease up to where you want.
"For a mechanic, you seem to do an excessive amount of thinking."
―C-3PO, to R2-D2
GLHS837 is offline
post #10 of 13 Old 06-26-2007, 09:54 AM
425hp
Senior Member
425hp's Avatar
I believe you will throw a code if you leave the IAT out. It codes for high or low, either shorted or dead. Some have resistors in the wiring and swear by it. I looked at one that had a resistor with my starscan and it was running at like 75 degrees. I think buying the extension and putting a resistor in it is the best approach. This way you can take the extension out when you wish and have normal operation, and put the extension in with the resistor for running at say the track.
C.
Silver 06 SRT-8
PPP 426ci.com Stroker, Track Warrior cam, half shafts, Mopar 392 Heads, Quaife LSD, Kooks LT headers, Dual Tbody intake, Corsa cat back, AFCO coilovers.
11.641 @ 116.805 (Best timeslip)
425hp is offline
  Dodge Charger Forums > Dodge Charger Discussion > V6 Specific Discussion
Gear in this thread - Powered by O'Reilly Auto Parts
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
Where Is The Iat(intake Air Temperature) Sensor Located On 2007 Dodge Charger? BLACKKNIGHT Performance Discussion/Modifications 5 03-04-2007 10:18 AM
Does the 6.1L have a knock sensor? high888 Charger SRT-8 Discussion 15 01-11-2007 01:07 PM
Relocation of IAT Sensor nCHARGE Performance Discussion/Modifications 35 06-06-2006 06:48 PM
K&N CAI IAT Orientation RTaddiction Performance Discussion/Modifications 10 03-17-2006 12:48 PM
Well, how much is an IAT sensor? CoastalHemi Performance Discussion/Modifications 8 03-14-2006 02:50 PM
You may post new threads
You may post replies
