Changing Rotors and Brake Pads - Dodge Charger Forums
Wheels/Tires/Brakes/Suspension Discussion about anything involving the wheels, tires, suspension components, etc.
Sponsored by: Discount Tire
post #1 of 12 Old 06-18-2007, 05:10 AM Thread Starter
Hemi 06
Senior Member
Hemi 06's Avatar
Send a message via AIM to Hemi 06
(Thread Starter)
Lightbulb Changing Rotors and Brake Pads
Can anyone help me with this. I ordered new drilled and slotted rotors and ceramic brake pads. Just wanted to know if anyone did this install. I wanted to see how hard it was for me to change them. If someone can give me a detailed set of instructions that would be great! I don't think it would be that hard, but im just not sure how to go about doing it. Thanks for the help in advance.
Jon
2006 Charger 5.7L Hemi
Daytona R/T Go Mango
Mods:Magnaflow Exhaust, 20" Foose Rims,Airaid CAI, Mopar Lighted Sill Guards, LED interior light bulbs, LED Smoke Tail Lights, 22 Elite Console Cover, 35 Tint
Hemi 06 is offline
post #2 of 12 Old 06-18-2007, 05:39 AM
crazylikeacharger
Senior Member
crazylikeacharger's Avatar
Send a message via AIM to crazylikeacharger Send a message via Yahoo to crazylikeacharger
okay i have replaced my brake pads and rotors with stockers but its pretty easy
you are first going to want to take and remove the caliper bolt near the rear of the car and then with that out you can pull up on the back of the caliper not the braket that holds it and it swivels up toward the inner fender. it may be tough but trust me it does swivel. then remove the pads by sliding them away from the rotor out of the guide slots. now you can get to removing the caliper bracket (2 or 3 bolts). now you need to remove the little locking washer type things that hold the rotor on. then swap the new rotor on. put the caliper braket back in and then slide the new pads in and get them up tight to the rotor. before you try putting the caliper back on take and open the brake fluid cap and by hand push the pistons in the caliper back. now try sliding it back over the pads and rotor. if it is too snug take back off and compress the caliper pistons more. then just make sure you put all the bolt back in and tighten then MAKE SURE YOU PUT THE BRAKE FLUID CAP BACK ON AND PUMP THE BRAKES WHEN YOU FIRST GET IN THE CAR AFTER!!
Too many mods to list now. reached the limit of this forum signature!!!!
crazylikeacharger is offline
post #3 of 12 Old 06-18-2007, 05:42 AM
crazylikeacharger
Senior Member
if you need any more info let me know
post #4 of 12 Old 06-18-2007, 06:32 AM
BaseCharger06
Senior Member
BaseCharger06's Avatar
Hmmm...swapping rotors sounds like an easy task to accomplish as you replace the pads. I guess with any brake change cleaning the rotors and bedding in is neccesary correct?
SE 3.5L V-6
35 DTI Window Tint, Blinker Mod, *Tinted Tails, *Daytona 18inch Wheels, SRT8 Trunk with Spoiler.
BaseCharger06 is offline
post #5 of 12 Old 06-18-2007, 06:38 AM
crazylikeacharger
Senior Member
yeah one thing i noticed that my right front was rusted. your best bet is to clean up the mating surfaces and clean up as much as you can to make it cleaner and easier to replace later down the road
post #6 of 12 Old 05-06-2014, 06:35 PM
Yuro
Senior Member
Yuro's Avatar
It was just this easy, however, i did the rears, and i couldnt compress the piston back by hand, had to use a clamp to compress it.
brake cleaner, 16mm and 18 mm, some lockjaw pliers or w.e. they r called, a mallot or hammer helps, some wire to hold the caliper up if u do change the rotors
screwdriver and pliers if it is your first time to grab the stupid rotor lock washer things offs
watch youtube once or twice, anyone can do this!
i know this is an old bump but this small quick thread gave me the motivation to knock this out asap
TorRed or NoRed!
"WTFO" Sponsored
WTFO weaponry:
Strut Bar V 2.1
"Being a good fiend is like being a photographer, you have to search for the right moment!"
Yuro is offline
post #7 of 12 Old 05-07-2014, 06:24 PM
JD13X
Senior Member
JD13X's Avatar
YouTube is your friend!
I used 2 different videos that people posted about changing the brakes.
One dealt with getting off those suborn rotors.
If you do the rears you will need a 15, and 19 mm socket / wrench as well.
JD13X is offline
post #8 of 12 Old 05-07-2014, 06:39 PM
PlumCrazyDaytona
Supporting Member (Lifetime)
PlumCrazyDaytona's Avatar
Send a message via MSN to PlumCrazyDaytona Send a message via Yahoo to PlumCrazyDaytona
Yes bedding the brakes is very important!!! They will grab better and last longer.
This is how I have done it and will continue to bed my brakes
http://www.zeckhausen.com/bedding_in_brakes.htm
6.1 Intake manifold,SRT MAX cam on 112lsa, CNC Inertia Heads milled,mopar TCM,blue tops, 3000 Edge converter 3.91 Getrag, Kooks LongTubes, catless mids and SLP Loud Mouth II, powerbond undrive pulley, 170 tstat, , R1 crossdrilled/slotted rotors, HAWK Pads,eibach lowering springs,dampners,sways mopar strut braces, razors edge sub frame connectors #157 of 1400 ACES IV Quantum Blue Lubricants PB 1/4 12.38@110.66
PlumCrazyDaytona is offline
post #9 of 12 Old 05-07-2014, 06:54 PM
Yuro
Senior Member
Yuro's Avatar
+1 on this, i did a "pre-bed" in, 45 to 5 around town after i put them on, since i have the zinc coated ones or whatever(black rotors), i must wait til that rubs off through regular drive cycles, then redo the procedure.
What a coincidence, i sent that same webpage to Drew earlier lol
Great minds...
Yuro is offline
post #10 of 12 Old 05-07-2014, 07:19 PM
Shade tree
Shade tree's Avatar
I used EBC drilled and slotted with their Red Stuff pads and it was a straight up replacement. While I was doing it I also painted the calipers.
Paramount Performance NAG1 Stage II Modified Valve Body, MOPAR Performance TCM, Precision Industries Double-Plate HEMI 2,800 RPM Stall Torque Converter, Arrington 85mm Cast Throttle Body, Ram AIR Hood, Zoomers cat back, Tune from HHP. LEDs in door pulls and in and under hood. Katskin Carbon fiber interior trim. red dash face. Added Red LEDs in door bins and cup holders on a dimmer
Shade tree is offline
  Dodge Charger Forums > Dodge Charger Discussion > Wheels/Tires/Brakes/Suspension
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
In need of rotors/pads... GotMe-N-R/T Wheels/Tires/Brakes/Suspension 9 07-15-2007 06:44 PM
SRT8 rotors and pads jasonface Wheels/Tires/Brakes/Suspension 14 04-14-2007 12:34 PM
New Rotors & Pads TonyV Wheels/Tires/Brakes/Suspension 25 10-26-2006 09:14 AM
Slotted Rotors AND Pads? GeorgiaSpeedRacer Charger SRT-8 Discussion 4 09-12-2006 08:09 PM
Impressions of new rotors with original pads Tampasrt Charger SRT-8 Discussion 5 08-17-2006 07:18 AM
You may post new threads
You may post replies
