Underbody plastic piece necessary? - Dodge Charger Forums
Exterior Discussion/Modifications Discussion of exterior modifications belongs in this section, even if the visual modification slightly affects performance (ie. spoilers, etc)
post #1 of 7 Old 05-29-2007, 08:34 AM Thread Starter
dcopel02
Junior Member
(Thread Starter)
I did like a lot of people I have read about on here have done....You know that plastic underbody piece? The one that covers the entire area below the motor? I tore mine up too...on a curb. Can I take it off for now? What will it hurt?
dcopel02 is offline
post #2 of 7 Old 05-29-2007, 08:39 AM
RitzRT
Senior Member
RitzRT's Avatar
Quote:
It won't hurt anything to have it off, but if it was me, I'd replace it.
Best,
Formerly had 2006 Charger R/T
Cool Vanilla <-- rarest color
Mods So Far: Hood struts, Cabin Air Filter
RitzRT is offline
post #3 of 7 Old 05-29-2007, 08:45 AM
sound&security
Senior Member
sound&security's Avatar
under body cover
it's 2 parts and the front one is needed to help hold the nose of the car tight at the bottom. with out it the nose will be lose and flex around-the rear one under the oil pan you can run it with out it and you will see the engine temp drop a couple of degress. the covers are there to keep water and dirt off the bottom of the motor and to cut down wind drag on the highway. if you have a r/t they are cheap to replace. the rear one is about $16 and the front i around $38 and most dealers have them in stock because they get thore up all the time
sound&security is offline
post #4 of 7 Old 05-29-2007, 08:56 AM
subliminal_hemi
Senior Member
subliminal_hemi's Avatar
I got my oil changed the other day at texaco and they told me they needed to take that piece off. I said it was cool so they went ahead and did what they had to do. Well later on in the week i hit about 100 mph on the interstate and the next exit i take i here something dragging every now and then. I pull over and its that damn black piece under the car. The dumbass didnt put it back on right. I havent yet got to see where they messed up, but it hasnt happened any more. I guess at just high speeds is when it messes with it.
subliminal_hemi is offline
post #5 of 7 Old 05-29-2007, 08:57 AM
CDJDMRJE
Senior Member
CDJDMRJE's Avatar
Quote:
Best,
In the last SRT Chat Session, the SRT Engineers said it was important for cooling purposes. I'd replace it. SOmebody asked if they could remove it to aid in cooling. Couldn't find the thread if someone could post it for this guy.
2007 LXDX48-21X, PS2; 2007 JSCS41-24B, PXR;2006 LXDP48-29N, PR3;2005 DR1S61-29S, PR4;2006 DR1S41-29S,PXR;2005 DR1S61-29S, PR4;2005 DR1S61-29S,PXR;2006 DH7H62-26G, PXR;2005 DR1S61-29S PS2; 2005 DR1S61-29S,PW1;2005 DR6H41-26G, PVE;2005ZHCS27-22A, PDR; 2005 WKJP74-27H, PXR, 2005 WKJP74-27H, PJT;2005 LXCS48-29N, PP4; 2004 HB5P74-28J, PR8; 2005 CSCS74-29S, PRH
CDJDMRJE is offline
post #6 of 7 Old 05-29-2007, 09:18 AM
RitzRT
Senior Member
RitzRT's Avatar
Quote:
It's possible they didn't get the interlocking tabs set up properly in the front and the wind "got under" the belly pan and pulled it off. There's 4 10mm bolts holding it on so perhaps they didn't tighten a few of them down all the way or didn't replace all of them?
Cheers,
RitzRT is offline
post #7 of 7 Old 05-29-2007, 09:59 AM
HemiChemi
Senior Member
HemiChemi's Avatar
Plus, leaving it off makes it that much easier to suck water into the intake if you drive though a deepish puddle. You don't want to hydrolock your engine because of a $35 piece of plastic!
Inferno R/T+R&T, EVIC; 6-disk CD; Sirius; UConnect; Protect Gp; front and rear spoilers, Daytona grille and insert, R/T emblem and hidden trailer hitch.
There are 10 possibilities:
you either understand binary, or you don't.
HemiChemi is offline
  Dodge Charger Forums > Dodge Charger Discussion > Exterior Discussion/Modifications
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
User Tag List
Search this Thread:
Advanced Search
Linear Mode Linear Mode
Similar Threads
IMPORTANT: Exterior/Underbody Rattle Fixes (Loose Plastic)! ChargerMadness84 Charger Problems/Assistance 1 06-24-2012 04:14 PM
LED Underbody Lights dispdan311 V6 Specific Discussion 22 05-02-2007 03:26 PM
LED Underbody Lights PikeBoy98 V6 Specific Discussion 42 02-01-2007 07:57 PM
Charger Underbody Picture realorc General Charger Discussion 6 10-18-2006 09:21 PM
all at once or piece by piece? Big Z Performance Discussion/Modifications 13 06-17-2006 02:41 AM
You may post new threads
You may post replies
